Asset UPnP for QNAP
This topic is closed.
    • 46139
    #181
    Re: Asset UPnP for QNAP
    If they are flac files, set in the configuration page for FLAC to be sent 'As Wav', this will allow Asset to decode the FLAC and our decoder is potentially way more robust than the Linn decoder.
    • kg648
      • May 2011
      • 52
      #182
      I'll give this a whirl tonight. thanks.
      Out of interest, apart from the file type would is cause any potential degrade in quality? or will it just present a different file format?
        • 46139
        #183
        Lossless is lossless (flac and wave are lossless), no quality is lost.
        • kg648
          • May 2011
          • 52
          #184
          Hi Spoon,
          Same issue with this change and asset restarted.
          To ensure networking was no way an issue I took the cable out of the qnap and put it into my laptop and ran the PC version of Asset, which appears to be working perfectly.
          A friend of mine who has a similar setup to me hifi wise and network wise and the same qnap 219p device, who also appears to have the same problem.
          So hopefully by doing that I have ruled out anything in my network or qnap or cabling or the streaming device.
            • 46139
            #185
            Send the file please, with something like dropbox if your email cannot send such large files:
            • kg648
              • May 2011
              • 52
              #186
              http://www.dbpoweramp.com/email.htm
              Should be in your inbox now
              • ponmarcn
                • Nov 2009
                Sorry if something not correct, I am new here,
                I have successfully installed Asset UONP on my QNAP 469 pro.
                Now it tells me that my free installation will end in three days.
                I purchase already 5 licenses on Assett premium, but I cannot buy the Qnap, or registered it.
                What can I do ? thanks
                  • 46139
                  #188
                  We currently do not have a registered version of Asset on the QNAP.
                  • kg648
                    • May 2011
                    • 52
                    #189
                    Hi Spoon,
                    Did you manage to reproduce the issue I raised and sent you some sample files for?
                    • dbfan
                      • Jan 2011
                      • 937
                      #190
                      We hope to look at this soon.
                      • JohnnyBGud
                        • Mar 2014
                        Hi Spoon,
                        Am running "Test10_0.1_arm-x19.qpkg" on a TS-421 with Firmware 4.0.2. Assett Library Contains 5872 Tracks, 715 Albums
                        Version: R4.2 Beta;
                        I am using Win8.1 with Windows Media Player as a client in a Workgroup (no Domain). The subnet starts with 192. . .
                        I can see the QNAP as a Media Library and can play tracks from the standard QNAP media Server. I can also see "Assett UPnP: <servername>" and all of the Albums with all of the tracks which are beautifully sorted (kudos!). The only issue is, is that I can't play any tracks. If I go to the "Properties" of a track I see the following (2 examples):
                        or
                        As my Network subnet starts with 192. . . I am not surprised that I can't play the files as the IP address is totally wacko!
                        Ah - I have an idea. ..
                        Assett is provisioning the files with an Open VPN client IP Address set in the QNAP. . . Any idea why? It have just checked the Properties of the Assett UPnP Server - its Device Website is listed as 10.8.0.1:45537 however under "Troubleshooting Information" it is listed with the correct 192. . . address of the QNAP???
                          • 46139
                          #192
                          Asset should bind to all IP addresses, and match the Control Point ip with one of its known, we need to look at this.
                            • 1641
                            #193
                            JohnnyBGud:
                            Very good report, thanks a lot. This will be addressed in the next Asset update.
                            • Declaration
                              • Jan 2014
                              • 23
                              #194
                              Originally posted by PeterP
                              JohnnyBGud:
                              When do we a new beta ?? or the final release.. I think the current beta runs out in a few days
                              • ocoro02
                                • Jun 2009
                                • 37
                                #195
                                Hi Spoon - I saw the message earlier from a TS-639 user getting the 'wrong architecture' error. I get the same on a TS-459 Pro II. 'uname -m' says 'i686' so, yes it is wrong :(
                                Is it possible to do a 32 bit build? Set the 32-bit compiler flags if it's C? (I'm chancing it here).
