Asset UPnP for QNAP
This topic is closed.
    • 46370
    #151
    Re: Asset UPnP for QNAP
    Update 19th February
    * Fixed crash in IP address enum causing Asset not to work on certain devices.
    * Prevented playback stall while indexing library.
    * .AAC files are now supported.
    • kg648
      • May 2011
      • 52
      #152
      Hi Spoon,
      Thank for that, downloaded and installed, I have set my watched media folder and saved, waited hit refresh and nothing, tried restarting and still nothing, it will not pick up my Music. :(
      I usual put just "/Music" in this box to pick up my files but it just seems to stick at;
      Asset UPnP: nas01
      Library Contains 0 Tracks, 0 Albums
      Version: R4.2 Beta; Functionality: Trial 30 Days Remaining
      Any suggestions would be great, I have also tried all the refresh buttons below this.
      UPDATE!!! fixed it, not sure why but now I have to put /share/Music instead - oh well.
      • Gandalf_fi
        • Jan 2014
        • 8
        #153
        I did the same mistake, took some time to realize to put "/share" in front of the directory. Please fix this if possible, small thing but... you know.
          • 46370
          #154
          Which Qnap model do you have?
          Is there a /Music folder as well as /share/Music on your system?
          • Gandalf_fi
            • Jan 2014
            • 8
            #155
            I have HS-210, by default it shows: /share/Multimedia/ & when I add my own directory I need to remember to add this /share in front of e.g. /Music
            • Gandalf_fi
              • Jan 2014
              • 8
              #156
              Clarification: there is /Multimedia folder only, not /share/Multimedia/
              • Declaration
                • Jan 2014
                • 23
                #157
                Anyone who has an arm x19 Qnap and have problems opening the config page, we have a special test version, uninstall Test9, install:
                If it works you should be able to get to the asset configuration page from App Center.
                for the first time i had access to the config page in my ethernet explorer. and.................. it works great job spoon
                • Declaration
                  • Jan 2014
                  • 23
                  #158
                  it works now
                  • Declaration
                    • Jan 2014
                    • 23
                    #159
                    It works now. Perfect .. Well done
                    • Declaration
                      • Jan 2014
                      • 23
                      #160
                      Hi spoon
                      The Special Version 9a is the First Version that worked for me
                      • kg648
                        • May 2011
                        • 52
                        #161
                        whilst listening this morning using test10 just had two drop outs mid track, CPU/Memory looking very low, no errors in the logs and it is not currently rescanning.
                        so not really anything to go on I am afraid. :(
                        • kg648
                          • May 2011
                          • 52
                          #162
                          all I see is the following;
                          ===========ProcessFileRequest================
                          Content Range: 0 to -1
                          SELECT * FROM t_artist;
                          SELECT * FROM t_album;
                          SELECT * FROM t_genre;
                          SELECT * FROM t_conductor;
                          SELECT * FROM t_soloists;
                          SELECT * FROM t_orchestra;
                          SELECT * FROM t_chorus;
                          SELECT * FROM t_instrument;
                          SELECT * FROM t_period;
                          SELECT * FROM t_style;
                          Serving File as is: /share/Music/Karl/Mark Knopfler/Privateering/16 - Bluebird.flac
                          Serve Entity Set to: audio/x-flac
                          BEGIN TRANSACTION;
                          UPDATE uMediaTable SET PlayCount=PlayCount+1 WHERE (FileNameIDX=1330);
                          COMMIT;
                            • 46370
                            #163
                            The update in your log would happen 5 to 10 seconds into the track, as nothing else is logged Asset is running as it should, what are the details of your network and the file you are serving?
                              • 1685
                              #164
                              If you are still experiencing dropouts while the library is being rescanned, please post (or email) Asset library logs from the time period when the problem occurred, these contain info that is relevant to us also.
                              • kg648
                                • May 2011
                                • 52
                                #165
                                I have a Netgear GS108, Qnap 219p, Draytek 2820n router and that's it from the network side of things.
                                I have tried minimizing the network a little however both devices go via the switch so the router is only used for DHCP.
                                I have a PC which uses Asset when not testing on the qnap which has no issues, also when using Twonky from the qnap which seems to be ok on the same files.
                                What sort of details would you require from the file? I mean it appears to happen on most files so I can't pin it down to one really - however it mainly seems to be FLAC's that I notice the problem on but most of my files are 24bit Flac.
                                If it happens on one track and I play the same track again a few times the problem might not happen again.
                                Let me know if I can provide anything further
