Asset UPnP for QNAP
This topic is closed.
  • andreynin
    Re: Asset UPnP for QNAP
    Thanks for the trial version, it's a great job.
    I have a question, I have made myself albums (flac) with various artists with MediaMonkey.
    The asset shows the songs as a separate album.
    I had also previously the double CD with an album on my N-Stream.
    The Twonky server displays the albums correctly.
    I am using N-stream.
    Can you tell me the right settings, I have now 200 albums more.
    Thank you
    Andrey
      • 46061
      #137
      If you have album artist set, then browse Advanced Search >> Album Artist / Album
      otherwise you can add the Compilation tag as '1' to the file ID tags and Asset will treat as Various Artist albums.
        • 1612
        #138
        Originally posted by flyingfufu
        Hi Spoon. Here below the result :
        (snip)
        and this continue indefinitively....
        Hope this help !
        Thanks, this is most useful.
        Please try running Asset with --upnponly switch, like this:
        ./AssetUPnP --upnponly
        Does it keep running or does it crash and return to command prompt?
        • andreynin
          I'm sorry, I do not know how to do that.
          • flyingfufu
            • 8
            #140
            Hi PeterP,
            Doing it, the following come out :
            [/share/MD0_DATA/.qpkg/Test9/bin] * ./AssetUPnP --upnponly
            Segmentation fault
            Of course no process get started on the NAS neither....
            Regards,
              • 46061
              #141
              You would use a tag editing program, either dBpoweramp or something like mp3tag.
              • his047
                Originally posted by charger93012
                Hey Spoon,
                Any chance of getting a x86 (not 64 bit build)?
                I've got a 259Pro+ that I'd like to use for this.
                +1 (for another x59 model: ts459)
                • Declaration
                  • Jan 2014
                  • 23
                  #143
                  tried to install the latest version for my TS212 , install stopped at 45% ..
                    • 46061
                    #144
                    The install is handled externally to Asset, it is a qpkg, the the nas installs it its self (just copying files). Try rebooting the NAS then retry.
                    • baardog
                      • Mar 2012
                      • 10
                      #145
                      Hey
                      Installed Test 9, today on my Qnap 659 Pro, and now it worked!
                      mvh,
                      Baard
                        • 46061
                        #146
                        Anyone who has an arm x19 Qnap and have problems opening the config page, we have a special test version, uninstall Test9, install:
                        If it works you should be able to get to the asset configuration page from App Center.
                        • flyingfufu
                          • 8
                          #147
                          Hi Spoon,
                          Thanks for the quick fix. I do confirm it is now working on my TS-419P+, and even publishing on the Network. I'm know in a position to try all functionality.
                          Regards,
                            • 1612
                            #148
                            Originally posted by baardog
                            Hey
                            Glad to hear.
                            I thought QNAP *59 series were Intel Atom but running 32-bit Linux? We don't currently provide a build for such. Did you install the version for x86-64 on yours?
                            Hi Spoon,
                            Regards,
                            Glad to hear it's resolved, thanks for confirming.
                            -P
                            • flyingfufu
                              • 8
                              #149
                              After 3 days of multiple tests, nothing special to report so far. It took some time for the scanning to complete and eated up to 85% of ressources, but once this step over, CPU usage is very low (approx 0.9%) event while "in use".
                              Only the radio feature need to be further tested.
                              Thanks a lot for this great job :happy: !!!
                              FF
                              • Gandalf_fi
                                • Jan 2014
                                • 8
                                #150
                                Yes, now it works with HS-210. Thanks.
