Codec Tags
  • Mujtaba
    • Dec 2018
    Codec Tags
    Hi sir,
    I’m converting some songs from mp3 to m4a using dbpoweramp.
    After finishing converting I see that the codec tags have additional text after “MPEG-4 AAC”.
    If you can help me to remove that information after the codec itself I would be very pleased. Thanks.
    • 44052
    Re: Codec Tags
    Where is this value shown? what is the extra text?
    • Mujtaba
      • Dec 2018
      Re: Codec Tags
      Thanks for the reply sir,
      The full text string is MPEG-4 AAC (fdkaac 0.6.3, libfdk-aac 3.4.22, VBR mode 5)
      For reference I am using two softwares at this time.
      1.dbpoweramp for converting and changing id-tags and the other one is mp3tag.
      When editing in dbpoweramp it shows a value at the bottom of the tags which is Encoding Tool (the string defined above except MPEG-4 AAC) Click image for larger version
ID:	293992 whereas in mp3tag, it shows the full string defined above Click image for larger version
      Please guide me to remove that Encoding tool tag in dbpoweramp
      Or is there any softwares that allow editing of codec tags.
      One more thing is that I have some songs that I have purchased from iTunes and they do not have these kind of extra tags, this only happens when I am converting mp3 files to m4a-aac format using dbpoweramp-codec-m4a FDK (AAC) Encoder from dbpoweramp.
      Thanks again for your time sir.
        • 44052
        Re: Codec Tags
        It is only possible to remove these tags after the files have been converted, we do not write that tag, the FDK aac encoder does. To remove them install the [ID Tag Update] utility codec from here:
        Use batch converter to select your root folder and set the encoder to '[ID Tag Update]' then on the settings page set to delete the Encoding Tool tag.
        • Mujtaba
          • Dec 2018
          Re: Codec Tags
          Does not work. There is no such option encoder tool in it.
            • 44052
            Re: Codec Tags
            You can manually type any value into the delete single box, it is:
            encoding tool
            • Mujtaba
              • Dec 2018
              Re: Codec Tags
              It seem that the encoding library is embedded into the file and not a editable tag.
