Small Unplayable File Size using Nimbie NB11
  • Bfb1963
    • Jun 2015
    I'm a new user. I just bought DBPA and a Nimbie NB11. I rip fine with DBPA choosing either my internal DVD player or the Nimbie Opticarc. However, when I use Batch Ripper with the same setting, it seems to rip as it should (as I watched it through DBPA) but the output is only 15kb files. Nimbie cycles through the discs, ejected in front for perfect rips and dropping them underneath for rips with errors.
    I saw in another post to disable antivirus, but that has not helped.
    Here is a copy of a rip:
    • 45615
    Re: Small Unplayable File Size using Nimbie NB11
    As a test, remove the multi-encoder, then rip to just wave, whilst ripping in batch ripper you can right click on the drive line and view CD Ripper (which is hidden).
    • Bfb1963
      • Jun 2015
      That did not work. It gave a .wav file size of 42kb. Here is the report:
      dBpoweramp Release 14.4 Digital Audio Extraction Log from Thursday, June 18, 2015 19:00
      Drive & Settings
      Ripping with drive 'J: [Optiarc - DVD RW AD-7261S ]', Drive offset: 48, Overread Lead-in/out: No
      Ultra:: Vary Drive Speed: No, Min Passes: 2, Max Passes: 4, Finish After Clean Passes: 2
      Encoder: Wave -compression="PCM"
      DSP Effects / Actions: -dspeffect1="ReplayGain= -albummode={qt}0{qt} -itunnorm={qt}1{qt} -r128lufs={qt}-18{qt}" -dspeffect2="HDCD="
      Extraction Log
      Track 1: Ripped LBA 32 to 13885 (3:04) in 0:15. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\01-Papercut.wav
      AccurateRip: Accurate (confidence 200) [Pass 1]
      CRC32: EDD42FEA AccurateRip CRC: 1858D89F (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-1]
      AccurateRip Verified Confidence 200 [CRCv2 1858d89f]
      AccurateRip Verified Confidence 200 [CRCv1 243ac6b4]
      AccurateRip Verified Confidence 13 [CRCv2 b506e9c], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 15381b84], Using Pressing Offset -664
      Track 2: Ripped LBA 13885 to 25560 (2:35) in 0:08. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\02-One Step Closer.wav
      CRC32: 82E570B8 AccurateRip CRC: DBED9926 (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-2]
      AccurateRip Verified Confidence 200 [CRCv2 dbed9926]
      AccurateRip Verified Confidence 200 [CRCv1 639d09f8]
      AccurateRip Verified Confidence 13 [CRCv2 4440bece], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 d0cc8f5a], Using Pressing Offset -664
      Track 3: Ripped LBA 25560 to 40805 (3:23) in 0:10. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\03-With You.wav
      CRC32: 2E2361E5 AccurateRip CRC: 66800618 (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-3]
      AccurateRip Verified Confidence 200 [CRCv2 66800618]
      AccurateRip Verified Confidence 200 [CRCv1 d95e7ba6]
      AccurateRip Verified Confidence 13 [CRCv2 40d9989d], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 a9a48ea2], Using Pressing Offset -664
      Track 4: Ripped LBA 40805 to 55825 (3:20) in 0:09. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\04-Points of Authority.wav
      CRC32: EB72AA1B AccurateRip CRC: 28587271 (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-4]
      AccurateRip Verified Confidence 200 [CRCv2 28587271]
      AccurateRip Verified Confidence 200 [CRCv1 d2a75db]
      AccurateRip Verified Confidence 13 [CRCv2 cc6c5258], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 cd0a5c7b], Using Pressing Offset -664
      Track 5: Ripped LBA 55825 to 71500 (3:29) in 0:09. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\05-Crawling.wav
      CRC32: 880C5533 AccurateRip CRC: DD0EAF7D (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-5]
      AccurateRip Verified Confidence 200 [CRCv2 dd0eaf7d]
      AccurateRip Verified Confidence 200 [CRCv1 d9c18e34]
      AccurateRip Verified Confidence 13 [CRCv2 7b9cc273], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 5338eb01], Using Pressing Offset -664
      Track 6: Ripped LBA 71500 to 85295 (3:03) in 0:07. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\06-Runaway.wav
      CRC32: 90BD5345 AccurateRip CRC: 2B33C918 (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-6]
      AccurateRip Verified Confidence 200 [CRCv2 2b33c918]
      AccurateRip Verified Confidence 200 [CRCv1 6abc2f07]
      AccurateRip Verified Confidence 13 [CRCv2 9dbf6827], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 c68eed6], Using Pressing Offset -664
      Track 7: Ripped LBA 85295 to 99530 (3:09) in 0:07. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\07-By Myself.wav
      CRC32: 48C4DB01 AccurateRip CRC: 5D3B14D0 (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-7]
      AccurateRip Verified Confidence 200 [CRCv2 5d3b14d0]
      AccurateRip Verified Confidence 200 [CRCv1 d699ac11]
      AccurateRip Verified Confidence 13 [CRCv2 4b3ee11f], Using Pressing Offset -664
      AccurateRip Verified Confidence 44 [CRCv1 dfe0318d], Using Pressing Offset -664
      Track 8: Ripped LBA 99530 to 115752 (3:36) in 0:08. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\08-In the End.wav
      CRC32: 34C6B9F9 AccurateRip CRC: CB5CB989 (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-8]
      AccurateRip Verified Confidence 200 [CRCv2 cb5cb989]
      AccurateRip Verified Confidence 200 [CRCv1 e9454db6]
      AccurateRip Verified Confidence 11 [CRCv2 fb35b70e], Using Pressing Offset -664
      AccurateRip Verified Confidence 41 [CRCv1 5a12f983], Using Pressing Offset -664
      Track 9: Ripped LBA 115752 to 129597 (3:04) in 0:06. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\09-A Place for My Head.wav
      CRC32: 2E7C303F AccurateRip CRC: 3FCB659F (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-9]
      AccurateRip Verified Confidence 200 [CRCv2 3fcb659f]
      AccurateRip Verified Confidence 200 [CRCv1 70499284]
      AccurateRip Verified Confidence 12 [CRCv2 ee1d21cc], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 25077840], Using Pressing Offset -664
      Track 10: Ripped LBA 129597 to 144182 (3:14) in 0:07. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\10-Forgotten.wav
      CRC32: 74F096C1 AccurateRip CRC: 733E3FA7 (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-10]
      AccurateRip Verified Confidence 200 [CRCv2 733e3fa7]
      AccurateRip Verified Confidence 200 [CRCv1 104d252a]
      AccurateRip Verified Confidence 12 [CRCv2 81c69c3b], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 37435319], Using Pressing Offset -664
      Track 11: Ripped LBA 144182 to 155972 (2:37) in 0:05. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\11-Cure for the Itch.wav
      CRC32: 1DD96DF2 AccurateRip CRC: 54FE05F1 (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-11]
      AccurateRip Verified Confidence 200 [CRCv2 54fe05f1]
      AccurateRip Verified Confidence 200 [CRCv1 eaf5c1e7]
      AccurateRip Verified Confidence 12 [CRCv2 b8c86df6], Using Pressing Offset -664
      AccurateRip Verified Confidence 42 [CRCv1 c59d9bc8], Using Pressing Offset -664
      Track 12: Ripped LBA 155972 to 170357 (3:11) in 0:06. Filename: F:\Linkin Park\2000 10 24-Hybrid Theory\12-Pushing Me Away.wav
      CRC32: 0384076D AccurateRip CRC: 424F8E8D (CRCv2) [DiscID: 012-0010e944-009e5fa9-a808df0c-12]
      AccurateRip Verified Confidence 200 [CRCv2 424f8e8d]
      AccurateRip Verified Confidence 200 [CRCv1 cd3d2755]
      AccurateRip Verified Confidence 12 [CRCv2 fc01b377], Using Pressing Offset -664
      AccurateRip Verified Confidence 40 [CRCv1 e0643b23], Using Pressing Offset -664
      12 Tracks Ripped Accurately
        • 45615
        What security software do you have?
        It looks like CD Ripper.exe is able to write to the audio files, but CoreConverter.exe is not allowed.
        • Bfb1963
          • Jun 2015
          Webroot.
          But again, CD Ripper works fine, just not Batch Ripper.
            • 45615
            Enable debug logging (in dBpoweramp Configuration) and rip the same CD with CD Ripper then Batch Ripper.
            • Bfb1963
              • Jun 2015
              I cannot upload the large debug file sizes. Looks like I am limited by the number of characters.
              Do you have an email I can use?
                • 45615
                Yes:
                • Bfb1963
                  • Jun 2015
                  sent
                    • 45615
                    Taking just the file Debug Batch Ripper.txt as that writes to just wave which shows:
                    Opening file 'F:\Good Charlotte\2002 09-The Young and the Hopeless\01-A New Beginning.wav' for write access: Opened
                    RIFF Header 'RIFF' Length: 19518136 FormType 'WAVE'
                    Got Chunk 'fmt ' Length: 16 RiffSizeLeft: 19518124 ChunkPosition: 12
                    Got Chunk 'data' Length: 19394592 RiffSizeLeft: 19518100 ChunkPosition: 36
                    Got Chunk 'LIST' Length: 220 RiffSizeLeft: 123500 ChunkPosition: 19394636
                    Got Chunk 'id3 ' Length: 123272 RiffSizeLeft: 123272 ChunkPosition: 19394864
                    This shows that in the above file there is a 19MB of data. If the wave file does not exist, then it is something outside of dBpoweramp which is deleting.
                    • Bfb1963
                      • Jun 2015
                      What programs can be doing this?
                        • 45615
                        I would not know what you have installed on the computer.
                        • PIANISTE97
                          • May 2021
                          Could batch ripper work with Nimbie NB11 and FLAC format ?
                          Thanx
                          Take care
