Synology R2026-07-29 Problem
  • jeanchrisFR
    • Jul 2026
    I don't have the same plain text copy. Will wait for the fix. Using embedded multimedia server in the interim.
    • Mike-B
      • Aug 2018
      • 223
      You do have the ‘plain text’ version of your browse tree.
      When to edit the browse tree to make it look however you want it, the plain test version of that is made in the Asset
      If you copy it & save it for use if it’s ever required
      • jeanchrisFR
        • Jul 2026
        Thanks Mike-B ... but since the R2026.07.29, I am not able to launch Asset application & access to the interface... and save the plain text version of the browse tree... but as soon as it is solved with the fix, I will do for sure !!!!
          • 1656
          It's possible that it's been fixed in new version-
          Current build: 2026-08-18 Downloads: macOS (https://www.dbpoweramp.com/beta/2026-08-18/Asset%20UPnP-2026-08-18.dmg) QNAP (https://www.dbpoweramp.com/beta/2026-08-18/Asset_20260818b.qpkg) Synology (https://www.dbpoweramp.com/beta/2026-08-18/Asset-R2026-08-18b-DSM7.spk) Linux: x86 32-bit (https://www.dbpoweramp
          Asset program for 32-bit x86 processors was removed from Asset Synology/QNAP packages a few months back because I assumed affected NAS models to be extinct. This has now been reverted. Please install it and report if it works.
          It appears that Synology DS214 Play is has an Intel CPU and runs 32-bit operating system, so this is likely it.
          It took me a while to figure this out because DS214 (non "Play" version) is reported to have ARM.
          • Mike-B
            • Aug 2018
            • 223
            Hi Peter, sorry no luck wit this beta, it has the same problem(s) as the current 07-29 release.
            As I said in a previous post, the release before 2026-07-29 worked perfectly on my Syn DS214 using DSM 7.1.1.(update 9)
            Installed is Asset-R2026-08-02b-DSM7.spk
            The iPad Naim app is open & the streamer is opening all its various app/functions normally -- except it will not open NAS (Asset)
            On the Synology GUI screen the installed Asset screen shows the correct installed details, but when the 'Run' button is pressed is goes to Running for a few seconds, then 'Manually Stopped'.
            The http // 192.168.1.***:45537/ command shows a screen with 'This site can't be reached' ... '192.168.1.*** refused to connect'.
            Sorry its not worked, I can wait and happy to try whatever you put forward.
              • 1656
              #21
              Please SSH to your Synology unit, run:
              Code:
              uname -a
              And post the output.
              • Mike-B
                • Aug 2018
                • 223
                #22
                Hi Peter ... sorry but this is getting into territory I am not familiar with - hence why I don't get involved with Beta testing.
                I've enabled SSH on Synology
                Opened Windows Command Prompt and follwed what I believe you are asking for
                It tells me its unable to negotiate with 192.168.1.*** port 22
                I fear I into stuff I don't understand and liable to screw something up
                Is there anything thats less IT I can help with
                • RayK
                  • Jul 2026
                  • 9
                  #23
                  Hi Peter. This installed successfully on my DS214play but won't run. I have tried to do the SSH but get permission denied after the password.
                    • 1656
                    #24
                    Another new build up. Does it help with DS214 ARM (not Play)? If it does, I'll apply the same fix to Intel version for DS214-Play.
                    • Mike-B
                      • Aug 2018
                      • 223
                      #25
                      Whoops 2026-06-03 shows 404 - File or directory not found
                        • 1656
                        #26
                        Sorry, fixed links now (didn't change folder name from yesterday)
                        • Mike-B
                          • Aug 2018
                          • 223
                          #27
                          Hi Peter, sorry no luck with 2026-08-03b-DSM7.spk
                          It has the same problem(s) as the beta-02b and the public 07-29 release.
                          My iPad Naim app opens normally & opens the NDX streamer and the various app/functions operate normally -- except it will not open NAS (Asset)
                          On the Synology GUI screen the installed Asset screen shows the correct installed details, but when the 'Run' button is pressed is goes to 'Running; for a few seconds, then 'Manually Stopped'.
                          The http // 192.168.1.***:45537/ command shows a screen with ... 'This site can't be reached' ... '192.168.1.*** refused to connect'.
                          I'm happy to keep testing but sorry I'm hindered by only rudimentary IT
                            • 1656
                            #28
                            Okay, thanks for confirming.
                            I'm working on identifying the casue and will get back to you in a few days.
                            • pete_l
                              • Nov 2011
                              • 8
                              #29
                              I have the same problem on my ARM DS214 (7.1.1). If you would tell me where to find relevant logfiles, I will gladly provide those.
                                • 1656
                                #30
                                New beta version runs on Synology DSM 7.1.1 again-
                                New compiler/runtime I started using can't handle very old Linux that Synology uses on affected models. I reverted offending upgrades for now.
