Synology R2026-07-29 Problem
  • Mike-B
    • Aug 2018
    • 223
    Installed 2026-07-29 on Synology (DSM-7) and it will not open streamer from iPad Naim app or access IP:45537 from Windows
  • Mike-B
    • Aug 2018
    • 223
    Re previous post ..... Screen message is
    This site can’t be reached
    "my" IP Adderess # refused to connect.
    Try: Checking the connection
    Checking the proxy and the firewall
    ERR_CONNECTION_REFUSED
      • 1656
      What Synology model is it?
        • 46228
        Tried to reboot synology?
        • Mike-B
          • Aug 2018
          • 223
          PeterP its a Synology DS214 with DSM-7
          Spoon, rebooted Synology and no change.
          It shows its installed on the Synology GUI
          Naim app on iPad opens and controls Naims iRadio OK, but not the Synology
          It was all OK with previous 2026-07-13 & 15
            • 1656
            Which exact version of Synology DSM it? We've had reports of DS214 with DSM 7.1.1 not working, but could not isolate cause or reproduce the problem on own Synology unit running newer DSM.
            Any luck with beta build from a few days back?
            Current build: 2026-08-18 Downloads: macOS (https://www.dbpoweramp.com/beta/2026-08-18/Asset%20UPnP-2026-08-18.dmg) QNAP (https://www.dbpoweramp.com/beta/2026-08-18/Asset_20260818b.qpkg) Synology (https://www.dbpoweramp.com/beta/2026-08-18/Asset-R2026-08-18b-DSM7.spk) Linux: x86 32-bit (https://www.dbpoweramp
            • Mike-B
              • Aug 2018
              • 223
              Hi Peter, DSM-7.1.1 42962 Update-9
              Its always worked OK on this revision
              I didn't try the beta, I don't get involved as limited time and even mor limited IT knowledge
                • 1656
                Okay, this is second case of DSM 7.1.1 having trouble with new Asset.
                Please stick with last-working version of Asset for now, we're investigating it.
                • Mike-B
                  • Aug 2018
                  • 223
                  It won't let me roll back ...... but no probs, I can wait
                  • RayK
                    • Jul 2026
                    • 9
                    Hi Mike-B
                    It wouldn't let me roll-back but was fine to uninstall and re-install older version
                    • jeanchrisFR
                      • Jul 2026
                      Hello,
                      Same problem here with 2026.07.29 :
                      - Problem : Asset application is launching ... and stop working almost immediately.
                      - Synology DS216j
                      - DSM version : DSM 7.1.1-42962 Update 9
                      The previous version 2026.07.13 was working properly. I cannot roll back because I no longer have the 2026.07.13 file to try the roll back.
                      Thanks for the help
                        • 46228
                        Try this version:
                        • jeanchrisFR
                          • Jul 2026
                          Just try. Unfortunately, it is not possible to revert back from R2026.07.29 to R2026.07.22 ...
                          • jeanchrisFR
                            • Jul 2026
                            Originally posted by RayK
                            Hi Mike-B
                            Uninstall & install again is not a good solution when you have a huge taylor made browse tree...
                            • Mike-B
                              • Aug 2018
                              • 223
                              I keep a plain text copy of my browse tree, it just adds a few moments to a reinstall
