Synology R2026-07-29 Problem
  • RayK
    • Jul 2026
    • 9
    #31
    Hi Pete.
    This installs and runs fine on my DS214play.
    Thank you.
    Ray
    • Mike-B
      • Aug 2018
      • 223
      #32
      Peter, the Synology file contains a Bot threat called ELF: Specter-C
      My PC security refuses to download it
      What to do ????
        • 46228
        #33
        Perhaps get better security software, Avast and AVG are the same and if you look here:
        https://www.virustotal.com/gui/file/8299a1237f1d51238d16a92769435ce647c5d2a2a4e358e16c ac6c42ade0e765?nocache=1
        and here:
        The following lists security software which is not performing as it should, that is blocking legitimate programs (such as dBpoweramp) from running. There is nothing we can do on our side, we produce legitimate software, virus free for the last 20 years, never once have we supplied a virus, Trojan, spyware with any of our
        They always miss detect, for 10 years, can do much better than those.
        • Mike-B
          • Aug 2018
          • 223
          #34
          OK, i got a bit alarmed when I read that Specter-C Bot targets Linux and my CPU runs Linux ……
          As you think it’s OK I’ll turn it off and download …. tomorrow
          • Mike-B
            • Aug 2018
            • 223
            #35
            Installed R2026-08-10 beta on my Synology DS214 DSM 7.1.1.(update 9) with Linux-ARM32
            All functions OK in all areas including ..http.. MyIP:45537
            .... THANKS .....
            I had to completely uninstall BT Norton to download the file,
            Disabling all functions did not stop it detecting what appears to be a trace of some sort in the file indicating it contains Bot threat d ELF: Specter-C
            Given that this Norton is the standard BT security package, it cannot be discounted as just a BT/Norton problem as it must be one of the UK's most installed security packages. [/SIZE]
            • Sturmgas
              • Jun 2026
              Thanks Thanks, after the official upgrade I had the same problem as mentioned. (Synology DS216Play DSM 7.1.1)
