Custom Tags and Vorbis Comment Fix Badly Needed
  • d2b
    • Aug 2010
    • 215
    When creating custom tags for ripping CDs to FLAC, dbpoweramp does NOT always obey the preferred vorbis comment recommendation and therefore we do not get the desired results.
    For some 'standard' fields, such as Composer, this entry
    COMPOSER=composer1; composer2
    results in these FLAC tags:
    COMPOSER=composer1
    COMPOSER=composer2
    This is correct behavior. However, for a custom PERFORMER tag entry like this:
    PERFORMER=Performer1 (Lead vocals, Instrument1); Performer2 (Instrument2)
    we get:
    As you can see, this is not correct behavior.
    When writing *custom* tags as vorbis comments, dbpoweramp should ALWAYS follow the recommended practice and create a separate tag for each entry unless otherwise specified.
    This is becoming a deal-breaker for us, as we want to expand on the basic set of vorbis comments in order to add important search tags to our radio station's music library. Performer is an essential tag required for each track.
  • d2b
    • Aug 2010
    • 215
    Re: Custom Tags and Vorbis Comment Fix Badly Needed
    Let me restate this problem:
    For some 'standard' fields, such as COMPOSER, entering this information in the Composer field in dbpoweramp, like this:
    COMPOSER=composer1
    COMPOSER=composer2
    This is correct behavior. However, when entering the values for a custom tag entry (Perfomer) like this:
    we get only one very long Vorbis comment:
    As you can see, this is not correct behavior. We should be able to get these vorbis comments (FLAC tags) instead:
    PERFORMER=Performer2 (Instrument2)
    When writing any tag as vorbis comments, we believe that dbpoweramp should ALWAYS follow the recommended practice and create a separate tag for each entry unless otherwise specified by an option for each tag field name. The options are there for a few standard tags, such as Artist, but not at all for any custom tags.
    Spoon...please address this issue.
    Thanks...
    "d2b"
      • 45548
      Noted, but we cannot commit to a fix timescale currently
      • d2b
        • Aug 2010
        • 215
        Spoon...
        That's all I can ask, and thank you for eventually addressing this issue. The sooner the better, but I understand the issues. In the meantime, I can always retag each track using Mp3tag.exe, but of course this is an extra and time-consuming step that is very unsatisfactory in the long run.
        Our major long-range goal is to convince artists and record companies to distribute music to radio stations, other professionals and discriminating collectors in lossless FLAC file formats, complete with a wide range of vorbis comments...anticipating the day when physical CDs and other optical discs go the way of 8-track cartridges and cassette tape. We're also looking for PDF 'booklets' of the current liner notes and lyrics to accompany the collection of tracks comprising an album.
        Your help with improving the ability to tag CDs converted to FLAC is appreciated....and essential to our work.
        Thanks...
        d2b
