Asset Control Discussions
  • Paul_G
    • Sep 2011
    • 18
    #376
    Re: Asset Control Discussions
    If you use Dynamic browsing, yes.
    Thanks Spoon, that works nicely. However, is there an easy way to get a track listing into the playlist without selecting each one individually? If you select an album via any route you can select the tracks to play by clicking om "play album". If you select a track list it seems you need a "play all" option?
      • 46213
      #377
      On the folder before the listing is a '>' item, click it to add to the playlist.
      • Chip
        • Aug 2008
        • 102
        #378
        Re: Asset Control Discussions - Disc/Track order
        Does Asset Control recognize Disc number in multi disc albums?
        I have many multi disc albums and I see all track 1s listed together instead of in disc order.
        What do I need to do to get the disc/track order correct?
        • dbfan
          • Jan 2011
          • 937
          #379
          It is the upnp server which does this, not control point.
          • DaveBk
            • Aug 2012
            First post here.... Just wondering when/if the iOS version of Asset Control is likely to hit the streets? I've been using dBpoweramp since '07, recently installed Asset in anticipation of getting a Naim NDS as I currently use a Transporter and Naim DAC. Currently I use iPeng and am very happy with it, but if I move to a Naim streamer I need a uPnP controller with as much functionality... I'm not sure Naim's nSteam is there yet, so I'd like an alternative.
            Thanks...!
              • 46213
              #381
              An iOS version is not currently under active development.
              • DaveBk
                • Aug 2012
                Ok, thanks for letting me know.
                • rsj
                  • Dec 2010
                  • 32
                  #383
                  Has development of Asset Control now ceased?
                    • 46213
                    #384
                    Pretty much so yes.
                    • j_j_Luc
                      • Oct 2012
                      Hello Spoon,
                      with my renderer "T&A Musiv Receiver e-series" is no gapless play possible. See the explanation of T&A
                      "Gapless Playback controlled by UPnP
                      Control Point
                      For gapless playback the streaming client must
                      always know which piece of music is to follow the
                      current piece. The UPnP protocol includes a
                      command for this which must be supported by the
                      UPnP Control Point (SetNextAVTransportURI).
                      Gapless playback is possible only if the Control
                      Point Application also supports the
                      SetNextAVTransportURI command in a correct
                      way.
                      To determine if your control point application
                      supports this command, please contact the
                      manufacturer of the Control Point application."
                      Is it possible to add the
                      "SetNextAVTransportURI" command to the asset controlpoint?
                      All my Music-Files are "Flac's"
                      j_j_luc
                        • 46213
                        #386
                        We will not support this method, as no other player supports it.
                        • JFP
                          • Jan 2009
                          • 13
                          #387
                          Too bad : there are not many worthwhile control point apps for Linn Ds
                          Kinsky is slow and updated not often enough, Songbook Lite and Chorus HD development seems idle.
                          I tried Asset Control on Windows 7 and it is great, I would be ready to buy the IOS version for my Ipad.
                            • 46213
                            #388
                            This year will see a flood of tablets which run Windows 8, Asset control would run very well on the intel versions of those tablets.
                            • exec
                              • Dec 2007
                              • 53
                              #389
                              Any idea when a final (non-beta) version should be available?
                                • 46213
                                #390
                                I would like to be able to give this answer, however I cannot pin a date just yet.
