Asset Control Discussions
    • 46160
    #331
    Re: Asset Control Discussions
    If the Uniti disappears from the My Network Players, when you are not even running Asset Control, try restarting your PC to see if it reappears, if not, then the Unity is invisible at that point on the network.
    • hokkaido
      • Oct 2011
      It doesn't reappear after a restart in either My Network Places or on the Zone screen. But Asset still works. Any other suggestions, please? Thanks!
        • 46160
        #333
        Asset would work as is Asset >> Naim, the issue is with Naim >> PC
        Naim would have to take over why it is having problems staying around.
        • hokkaido
          • Oct 2011
          Thank you for the reply. I have spoken to Naim in the past with things like this but they say it's an Control Point / UPnP issue. Anyway, I will see what they say this time. Thanks!
          • drgrittani
            • Jun 2004
            • 10
            #335
            I may have spoken too soon in post 324. Sorting and adding to playlists and shuffle works better, but now Asset Control freezes regularly. After two or three tracks play, it just freezes, and I have to hit the Windows button to get back to the desktop, then right click Asset control on the toolbar and close it. My setup is as described in post 269 ( http://forum.dbpoweramp.com/showthre...l=1*post108933) , the only difference now is I have updated to the latest version of Asset uPnP on my WHS and I'm using the latest Asset Control. Are there any logs or something that I can post to help debug this?
              • 46160
              #336
              There are issues with asset control freezing, hence why it has yet to release from beta, the next update fixes a freeze, but there could be more...
              • drgrittani
                • Jun 2004
                • 10
                #337
                I can't seem to get by 10 songs with this last 2011 release without freezing, in my WinXP setup. Is there any chance you could point me to the last 2010 release, so I could reinstall that? The playlist bugs I had were relatively minor and it didn't freeze. Otherwise I'll have to go back to itunes or WMP.
                • balma01
                  • Oct 2010
                  • 107
                  #338
                  Hi everybody,
                  I've asset control that correctly reads my asset upnp library. Sometimes I see som albums without cover art and I add it to all the songs using mp3tag. I close and reopen asset control but the cover is not shown, but if I click on the album I see the cover. How to refresh the main navigation screen?
                  • dbfan
                    • Jan 2011
                    • 937
                    #339
                    Asset upnp needs to rescan the tracks with a refresh all, asset upnp r4 will automatically detect changes in album art.
                    • JoeBroesel
                      • 36
                      #340
                      Sorry such is not possible in that the server would not pass these custom tags to the control point, as only a few standard tags are defined.
                      but isn't the server also from dbpoweramp, and could you not change that?
                      J.
                      Linn Klimax DS --> Accuphase CX260 --> BM35
                      • Chip
                        • Aug 2008
                        • 102
                        #341
                        Is Asset Control Davaar compatible?
                          • 46160
                          #342
                          Asset Control is Davaar compatible.
                          • philw
                            • Dec 2010
                            Re: Asset Control Discussions/ AssetUPnPv3 + AssetControl
                            Just trying to get this working streaming FLAC from Win-7/64. I have used Asset UPnPv3 for a while, but now I need a control program.
                            Kinsky doesn't seem to be able to reliably control AssetUPnPv3, so I switched to AssetUPnPvBeta4 but it's still not really working. It'll stream etc but control is hit and miss - sometimes things play, sometimes it won't play anything. I'm streaming to a Naim Qute but that's not really relevant; the Naim can suck data from Asset with no issues.
                            AssetControl sounded like a better bet as it should work with Asset UPnP. So far, issues seem to be:
                            1. It takes over my whole screen. This is a 30" monitor, filled with blackness. I guess the program's intended for pocket devices. That makes it hard to use on a PC. Kinsky shares the (probably fashionable on iPads) black design, but at least that can be resized so it's not so harsh. I could run it in a virtual machine configured with a tiny screen size, but, really a Windows program needs to run in a window.
                            2. Playback with Asset 3 and 4 Beta is idiosyncratic. Some "CDs" simply don't stream, although they stream ok from Asset V4 via Kinsky. Other times the play seems to jump from track to track without obvious input from me.
                            3. The click-model is difficult for PC users to grasp. If I was stabbing a fondle slab it may make sense, but for PC users it breaks the paradigm. Most users expect to click (control-click etc) to select, and double-click to action something.
                            4. The task crashed once; no obvious reason why.
                            Overall it is it's a lot of hassle trying to drive it to do what I want. I'll have to stick with the Naim's remote control in the mean time. Not sure if I should back off to Assetv3 or stay with AssetV4; will have to see if it works reliably from the RC.
                            • Burette
                              • Oct 2011
                              Problem with WD TV live,
                              I know it's lame but I have a LINN system with CD and I am saving for a LINN DS so I am running a WD TV Live.
                              Control is not working properly. It jumps from track to track without my input or it just disconnects from the WD TV.
                              The WD TV can be controled without problem from Twonky, PLugPLayer.
                              Any help on that?
                                • 46160
                                #345
                                There are known issues with the WD Live.
