How to Optimize M4a Layout without converting!
  • gerchuska
    • Aug 2013
    Hi! :blush:
    I have thousands of files in m4a that I've encoded over the last ten years using NeroEncoder and the files have played well in itunes.
    However, the same files don't play in ipod shuffle while they do in itunes app. I've done some research and have found out that the problem is to do with the tag headers and the solution is to optimize the file.
    I tried converting and optimizing in dBpoweramp and it did the trick but I'm coverting a lossy file to a lossy file...:(
    How do I do to use the m4a optimize feature in dbpoweramp without converting the files?
    Hope someone can help me,
    Ger
    • 46201
    Re: How to Optimize M4a Layout without converting!
    Try install the [ID Tag Update] utility codec, then convert the files to this encoder it will rewrite the tags, if you are lucky they will be in the right place.
    • gerchuska
      • Aug 2013
      Thanks! I tried but I was not lucky! :cry:
      • SteveM49
        • Aug 2014
        • 9
        How do I post a new thread? The GUI confuses me.
        I'd like to ask for the procedure to convert an already digitized album (in mp3) to a wave file on a CD that I can listen to in my car.
          • 46201
          Install CD Writer and the 32 bit version of dBpoweramp (force the 32 bit version by hold right shift key whilst install):
          http://forum.dbpoweramp.com/showthre...-Compatibility
            • 6189
            click on forum button (next to what's new button). Then click on the name of the appropriate forum for your post. Then click on POST NEW THREAD button at upper left.
