Removing 'Comment' Tag In A Single Pass
  • monsterjazzlick
    • 1764
    #46
    Re: Removing 'Comment' Tag In A Single Pass
    ... in the meantime I have spent a couple of hours going through every CD I have ripped and double-checking that every single 'comments' field is blank. And applying Oggy's system of tagging boxsets to all relevant files. This way, I will - hopefully - know that the issue is 100% not related to dBpa. Cheers.
    • monsterjazzlick
      • 1764
      #47
      ... I have reinstalled foobar with the additional d/l dll files, and searching strings, and Gary's layout scheme.
        Hi mville, I am sure everything was set up correctly previously - in the way you describe above thanks. But I will make extra sure it is set as it should be when I configure it later. Thanks.
        EDIT: and here is screenshot of 'properties':
        I don't know what it is about your pics, but I can never see them. Are you using the Insert Image button? I have seen plenty of other posts today and they contain pics that I can see.
          Evidently it is because he posts so many pics in one day that it triggers moderation, and spoon or someone has to release them. I can never see them either until long after the question has already been answered.
          • monsterjazzlick
            • 1764
            #50
            Thanks for letting me know. I can see them fine? I will notify the moderator again. Cheers.
