Cd toc
  • Salem874
    • Sep 2006
    • 70
    Cd toc
    Which ripping formats support storing of CD TOC in the metadata?
    I know WMA does, but is this the only format?
    What I'd like is to use a Lossless codec (I've recently settled on Apple Lossless) which can store the original CD TOC fore future reference/reuse?
    Which formats support this?
  • Salem874
    • Sep 2006
    • 70
    Re: Cd toc
    Spoon, I've actually just found this: https://musicbrainz.org/doc/Disc_IDs_and_Tagging
    which seems to suggest iTunes/Apple (so i'm assuming ALAC as well) does support some form of CD TOC embedding.
    Can you confirm that this is something you're aware of and which (if any) of the above (or other) formats dB PowerAmp Music Converter and CD Ripper supports embedding CD TOC for?
