Problems with Batch Ripper
    Re: Problems with Batch Ripper
    Perhaps you have overread enabled in CD Ripper? or are ripping to a network share, both of these can freeze the ripping (it must be pointed out it is not CD ripper at fault).
    • ricsimas
      • Mar 2011
      • 11
      I'm assuming over-read is set by that Read into Lead-In Lead-Out setting? If so, it's disabled. I'm defaulting to Secure Ripping, by the way, and, as I mentioned, everything works in the regular CD ripper (if these settings are available separately for the Batch Ripper, I couldn't find it).
      As for the network share comment: it's ripping to a local drive. This drive is set as shared over the network, but I'm assuming this is not what you meant by network share?
        It all seems good, you can right click on the drive in Batch Ripper and select 'Show Ripper', batch ripper uses the normal CD ripper (hidden) for ripping.
