Problems with Batch Ripper
  • ricsimas
    • Mar 2011
    • 11
    I set up Batch Ripper with autorip to have my server PC work as a ripping machine. It worked fine for several weeks, but since a couple of days ago the Batch Ripper has become temperamental, as is often in a state of Post-load Waiting for CD.
    A few CDs it can still rip, but even some that dBpoweramp rips easily will put it in that state.
    Is there something I could do about it?
    Thanks in advance.
    Re: Problems with Batch Ripper
    Look in Windows explorer at the CD drive, it should say it is an audio CD and display a track listing as
    Track01
    Track02
    etc
    • ricsimas
      • Mar 2011
      • 11
      That is what it shows in Windows Explorer, but Batch Ripper stil states Post-Load waiting for CD
        The drive letter is the same? ie same as in explorer as to what Batch Ripper is using?
        • ricsimas
          • Mar 2011
          • 11
          Yes, same drive letter.
            Do you have any security software?
            • ricsimas
              • Mar 2011
              • 11
              Just MSE, but that has been true during the entire life of this machine.
              • ricsimas
                • Mar 2011
                • 11
                Hi Spoon - any suggestions of next steps, please?
                  If whilst it is waiting for CD, yet there is one inserted, if you run CD Ripper, does it show a track listing?
                  Check also you not have any virtual cd software, any other anti malware programs (MSE is fine), no programs in the tray which might interact with CDs.
                  • ricsimas
                    • Mar 2011
                    • 11
                    The regular ripper works perfectly despite that message in the Batch ripper.
                    [/quote]
                    I don't think it's the case - only thing that could be vaguely related is the Intel Storage perfomance thing, but I don't think it does anything to the CD Drive. It's also been there since the beginning of this build.
                      You are using Release 2 of Batch Ripper?
                      • ricsimas
                        • Mar 2011
                        • 11
                        I'm sure this will make me look stupid, but how can I tell?
                          Run dBpoweramp Configuration.
                          • ricsimas
                            • Mar 2011
                            • 11
                            It's release 1.5.
                            • ricsimas
                              • Mar 2011
                              • 11
                              Just installed R2. Initial results were encouraging, as it started ripping the CD, but it won't end the process - it stays there "ripping" the last track forever. This is something I experienced a couple of times with R1.5 as well.
