General Tags Problem (Bug??)
  • jrk-sc
    • Jun 2024
    • 25
    There seems to be a bug with "Artist Sort" and "Album Artist Sort".
    I can set "Artist" and "Album Artist" to "AC/DC" without a problem. However, if I set "Artist Sort" or "Album Artist Sort" to "AC/DC" it insists upon changing them to "AC; DC". This occurs in both PerfectTUNES and CD Ripper.
    Is this by design (some standard?), or can it be fixed? The way it is now, it sure messes up sorting.
    Thanks!
    Jon K
    Which audio format? mp3?
    • jrk-sc
      • Jun 2024
      • 25
      Ah, interesting question... never occurred to me that it might be encoder-specific! Well, I just double-checked, and AIFF and MP3 exhibit the problem, but FLAC does not. Can't say regarding other encoders--I only encode in those 3 formats.
      (I generally avoid MP3--it is only for my car. I use AIFF for Apple apps, and FLAC everywhere else. Encoding in 3 formats simultaneously is one of the things I truly LOVE about dBpoweramp!)
      • simbun
        • Apr 2021
        • 264
        In ID3 v2.3 (tagging format used by MP3) '/' is a field delimter so you're better off choosing 2.4, although make sure to test it with your players first:
        Code:
        dBpoweramp Control Center > Audio Codecs: List Options > mp3 ID Tagging: ID3v2 Version
        I know nothing about AIFF so I can't help you there.
          It (mp3 id3v2) is such a bad standard programs need a list of all known artists with '/' in the name and keep them as one, not two. We will update that code to work on the sort values.
          • jrk-sc
            • Jun 2024
            • 25
            Does AIFF use the mp3 id3v2 standard, or is another fix required for AIFF?
            Thanks!
            Jon K
            • simbun
              • Apr 2021
              • 264
              Jon K
              Just to be clear, the "fix" Spoon is taking about is just to make it look like one tag in CD Ripper and PerfectTunes, it'll still be 2 tags as per the spec, and who knows how other applications will treat it e.g. MinimServer will split them into two tags and I'm sure others will too.
              Mp3tag uses NUL as the delimiter and foobar2000 uses '[space]/[space]'. v2.3 really is a mess!
                AIFF is id3 also in a chunk
