  • monsterjazzlick
    • 1764
    #346
    Regarding ARTIST and ALBUM ARTIST, please, I am thinkin' of modifying what I have been doing originally! I read some pages back about how (I think it was Oggy?) someone made a distinction between different sized ensembles of the same bandleader.
    So, I have written (for ARTIST and ALBUM ARTIST): 'Miles Davis' in both fields. But now, in hindsight, I wish I had included then size of the ensemble:
    eg. 'Miles Davis Sextet', 'Miles Davis Quintet', etc.
    But which field would this information go in, please? ARTIST or ALBUM ARTIST
    Paul
      • 6186
      #347
      Cheers Gary, I did actually notice some slight blemishing on the CD when I looked closer. I only have 1 PC so no options for another drive, I am afraid. Paul
      You can always add another drive to your existing PC. I use a second full size drive in a USB housing that I simply connect to my PC via USB cable.
      Note that you will not necessarily see anything wrong with a CD. I've had brand new, out of the package, never played CDs that had ripping problems. Probably a minor manufacturing defect. Also keep in mind that I've had some rips where a track never got a secure rip, but yet a close listen seemed that it played OK. Keep in mind that what makes it insecure might only be a few frames, which could be .00001 of a second in time (just making that up, but think "tiny, tiny amount of time").
        • 6186
        #348
        Paul
        I put the actual artist name for the CD in the ARTIST name (e.g., Miles Davis Sextet) and then put Miles Davis in ALBUM ARTIST. For example, for Doug Sahm, I might have any of these CDs by him under these names:
        Sir Douglas Quintet
        Doug Sahm & Band
        Sir Douglas Quintet Plus 5
        The Masked Men
        and on and on.
        But for all these, I use "Doug Sahm" in the ALBUM ARTIST.
        • monsterjazzlick
          • 1764
          #349
          Hi Gary, I was thinking of buying a second laptop (for for work, one for home) but I am still toying with the idea of the Amazon Fire HD8. But the latter does not have a CD drive.
          All of my CDs are in good condition although quite a few of the cases are cracked, and I am noticing the booklets to start yellowing with age. Paul
          • monsterjazzlick
            • 1764
            #350
            Sir Douglas Quintet
            Doug Sahm & Band
            The Masked Men
            and on and on.
            Cheers Gary, That's a very good explanation. But in the case of 'The Beatles', would both the ARTIST and ALBUM ARTIST fields be: 'The Beatles'? I mean, there is no personal name; but rather an ensemble name. Paul
              • 6186
              #351
              Correct, for most artists I have, the ARTIST and ALBUM ARTIST would be the same (e.g., The Beatles for both). In my personal scheme I leave ALBUM ARTIST blank unless something like the Miles Davis or Doug Sahm examples, or if it is, for example, a tribute album to an artist (and I make the ALBUM ARTIST whoever the tribute is to). This said, many people fill ALBUM ARTIST always.
              • monsterjazzlick
                • 1764
                #352
                ... also, please, if 'Miles Davis Sextet' is the ARTIST, then how do I configure ARTIST SORT? Typically, if just a christian and surname then one would write: 'Smith, John'. But 'Miles Davis Sextet' has three components?! Paul
                  • 6186
                  #353
                  My laptops no longer have CD drives either. I use USB 3.0 connected drives, such as:
                  Enclosure:
                  Drive:
                  • monsterjazzlick
                    • 1764
                    #354
                    Gary, that's interesting about the 'Tribute' recordings. I had not thought about that. Paul
                      • 6186
                      #355
                      I'd make ARTISTSORT = "Miles Davis Sextet" and ALBUMARTISTSORT = "Davis, Miles"
                      • monsterjazzlick
                        • 1764
                        #356
                        Much cheaper that I would have thought!
                          • 6186
                          #357
                          For example "The Pyramid Meets the Eye" is a tribute album to Roky Erickson. There are lots of different artists (but NOT Roky Erickson). But I put "Roky Erickson" as ALBUM ARTIST so when I browse artists in my library, this tribute album shows up with my actual Roky Erickson albums.
                            • 6186
                            #358
                            More expensive drives don't necessarily rip better. I've got a couple of 15 year old cheap drives I've saved and have installed in my work "desktop" computer. These are great for ripping!
                            • monsterjazzlick
                              • 1764
                              #359
                              OK, thanks. So no reordering of names for ARTIST_SORT then (ie. when: Sextet/Quartet etc). But, when both the ARTIST and ALBUM_ARTIST is: 'Miles Davis' (which will crop up on a few CDs), then should I use: "Davis, Miles" for both? Cheers.
                                • 6186
                                #360
                                You can do whatever you want of course. It's not a law of nature. But that's the only thing that makes any sense to me. Personally, I don't use SORT tags at all.
