Resampler in dBpoweramp, is a high quality resampler employed?
This topic is closed.
This is a sticky topic.
    • 46230
    Over at HydrogenAudio is the Sample Rate Conversion Comparison https://src.hydrogenaudio.org
    The popular Sample Rate Conversion routines are pitted against each other, across various tests: https://src.hydrogenaudio.org/technical
    Let us jump straight in, dBpoweramps ARDFTSRC against Adobe Audition (recent version):
    https://src.hydrogenaudio.org/compareresults?id1=2e6d9ef1-9d6b-4586-9786-a6fb41fab152&id2=08b2dee5-102a-4d92-ab66-2dbb385a8de3
    Let us delve into the components which make up this result.
    A respectable result for both. Impulse Frequency next:
    A clear difference, here the Adobe resampler is -180 dB on the response, dBpoweramp -320 dB. This can also be seen on the intermodulation test:
    Impulse Response and Phase next:
    Very similar for both, Linear phase, note the lower score for Phase is weighted towards a minimum phase response, yet this would adversely effect other components of the test.
    • 46230
    Sox has a well respected SRC, we test here v14.4.2, very high quality with extended bandwidth (99%):
    Onto the components of the test:
    Very similar. Bandwidth now:
    Here Sox is around 99% preserved. Impulse frequency:
    There is the difference, Sox is likely limited here by the 32 bit float format which is the highest this cmd line accepts.
    Finally gapless abilities, if converting two tracks from a live album, where one ends and the other starts straight without silence, we are looking for a good transition:
    As we can see Sox cmd line is not optimal on gapless handling, that transition is likely audible and also hard clips.
      • 46230
      Much research has gone into squeezing the last bit of performance out of ARDFTSRC, implementing two tapers, depending on mode, we are pleased to note we have as of today (in the forthcoming R2026-05-25) release, worlds best for sample rate conversion:
