OPUS Setting Request
  • thexfile
    • Jul 2010
    • 177
    Could OPUS have 1024kbps added to VBR encoding setting?
    I've been playing around converting 6ch 24bit 96Hz flac to opus and 512kbps is listed as max setting. I noticed GoldWave has 1024 and 2048kbps setting for opus.
    Even though 512kbps is being used the audio is still clear. I ripped Queen "The Game [5.1] 24bit 96Hz." The total folder size of the flac is 1.83GB after converting to opus 6ch the total file size is 133MB.
    Update: The goldwave 2048kbps is only for [7.1]. 1024kbps is used for [5.1] and [7.1].
    Re: OPUS Setting Request
    I think we can for next update
    • thexfile
      • Jul 2010
      • 177
      Thank you.
      If you like a audio sample I can PM a link.
