Save ISRC without hyphens
  • Hyronimus
    • Oct 2010
    • 18
    I'd like an option in CD Ripper to save the ISRC without hyphens.
  • smisk
    • Jan 2009
    • 61
    Re: Save ISRC without hyphens
    My drive for ripping (Plextor premium2) is reported as being able to read ISRC, but cd ripper does not read them. (Also does not report UPC, but don't know whether the ripper software suppors this field). Running on WinXp x86 with scsi passthrough.
    Settings in Metadata/IDTag options are checked for both UPC and ISRC. Both these are also enabled for perfectmeta retrieval. ISRC does not show up on main screen neither on insert nor after ripping is finished, also not in the encoded files. Why?
    Manufacturer: PLEXTOR
    CD Drive: CD-R PREMIUM2
    Firmware: 1.03
    Serial: 10/01/07 16:00
    Maximum Speed: 7056 KB/sec (x40)
    Current Speed: 7056 KB/sec (x40)
    Spin-down After: 2 minutes
    Buffer Size: 8 MB
    Accurate Stream: Yes
    C2 Error Pointers: Yes
    Reads ISRC: Yes
    Reads UPC: Yes
    sample idtags from one recently ripped track:
    Artist Human League
    Title Don't you want me
    Album Absolute 80's vol 1
    Track 04
    Disc 1/3
    Genre 80s
    Year 1981
    Rating
    Composer Callis; Oakey; Wright;
    Size 8,97 MB (78% Compressed)
    Original Size 39,56 MB
    Length 3 minutes 55 seconds
    Channels 2 (stereo)
    Sample Rate 44,1 KHz{CR}
    Sample Size 16 bit
    Bit Rate 320 kbps
    Encoder LAME 3.99r
    Encoder Settings Constant Bit Rate 320 kbps (Insane)
    Audio Quality Very High (Lossy)
    Contains Album Art, ReplayGain, ID Tag [ID3v2.3]
    Channel Mapping Left, Right
    File 04 - Human League - Don't you want me
    Type MPEG Layer 3 Audio File [.mp3]
      • 46217
      You would have to specifically Metadata drop menu >> retrieve from >> isrc
      • smisk
        • Jan 2009
        • 61
        CD-ISRC and CD-UPC were already checked. If I chose Retrieve from - CD-ISRC nothing happens. If I first clear metadata then Retrieve from - CD-ISRC, nothing still happens. Same for UPC.
        Tried it on my workstation (non-ripping) machine, doesn't work there either. (It's enabled in ripper-options-metadata and in ripper-metadata as specified above)
        Code:
        Manufacturer: 	Optiarc  (Sony)
        CD Drive: 	DVD RW AD-7241S
        Firmware: 	1.03
        Serial: 		 Oct06,2009
        Spin-down After: 	8 minutes
        Buffer Size: 	2 MB
        Reads ISRC: 	Yes
        Reads UPC: 	Yes
          • 46217
          Some drives tell lies about their abilities...
          • smisk
            • Jan 2009
            • 61
            ISRC extraction works fine using PlexTools XL 3.16 on the Plextor Premium2 drive (winxp) - with the same disc that i tried with above.
              • 46217
              Some plextors had non-standard ways of reading things such as ISRC and c2.
              • tom-ILM
                • Oct 2012
                I have the same problem with Plextor PX-880SA and PX891SA- I can read ISRCs with other rippers but dBpoweramp.
                Spoon, do you have a list of CD drives that dBpoweramp actually "likes" in terms of extracting the ISRC codes?
                  • 46217
                  Sorry I do not.
                  • tom-ILM
                    • Oct 2012
                    Shame.
                    Any chance for tweaks (Re.ISRCs extraction) that would make CD ripper much more flexible and as a result Plextor drives friendly?
                      • 46217
                      It is not planned as I am not sure of the code to fix it.
                      • d2b
                        • Aug 2010
                        • 215
                        Are you sure that the ISRC and/or UPC is actually available on the CDs? I always rip from one or two CD players and only occasionally do I get ISRC data and almost never UPC information. I assumed and still do believe that the information is just not there to retrieve on many CDs.
                        If it is there, I certainly want both. Sound Exchange here in the USA wants ISRC data reported as part of their scheme to collect data on Internet 'radio' streaming.
                        -d2b-
