Midi codec
This topic is closed.
    Midi codec
    can we get a midi encoder/decoder? that would be helpful for me at least
  • Razgo
    • 2532
    I think converting midi will always be a hard issue. because of the nature of midi it will always be difficault to achieve good results.
    if anything perhaps the ability to play a midi file (without the conversion bit) would be nice.
    a lot of people just run a cable from the output of the soundcard and loop it back into the input and then play and record at the same time into another format.
      midi plz
      Is it necessary to worry about quality when converting to a midi? Would anyone be doing anything with the midis other than making ringtones? That's all that I want the midi for.
      • Razgo
        • 2532
        ringtones? there are millions of music midi files out there.
        hmmm... well all you need to do is what i said in the previous post using your sound card. or you could download awave studio as it will convert from midi. http://www.fmjsoft.com/awframe.html
        is there a specific ringtone you wanted? i'm sure there would be some in wav format around.
        • Razgo
          • 2532
          ooops, just realized you wanted to record ringtones in midi format?
          • ddominey86
            • Aug 2002
            • 14
            converting from midi would only be easy, u would need to ude the directx built-in dls file(which contains wavs of all the istruments). all that might be hard is the mixing of the wavs into one wav output
            • Atlantima
              • Aug 2003
              Re: midi plz
              I have a bunch of midi's that I want to put on a cd.
                Re: Midi codec
                You happened on one of the oldest threads on this.
                Many other threads on why and why not and what to do, but see here: http://forum.dbpoweramp.com/showthread.php?t=3934
                  Re: Midi codec
                  Please don't revive 2-year old threads that you apparently didn't even read.
                  Thread locked.
