64-Bit and/or GPU encoding options?
  • volvoguy
    • Nov 2004
    • 17
    Hey all!
    I've been an illustrate product user for a LONG time, and usually I'm behind the technology curve - but I just got a new iMac (no, not asking what you think. hehe) and I'm running Windows 7 on it as well with Bootcamp.
    I'm not sure how much a 64-bit version of the ripper/converter software would speed things up, but I've been playing with some of the Nvidia CUDA accelerated video encoders and plugins and they make a HUGE difference when you use the GPU for acceleration.
    AFAIK, you don't have to pay to use CUDA, so there shouldn't be a problem there. I would also think that a "render using GPU (for supported video cards)" checkbox would make it easy to enable/disable that feature for people that can or can't use it.
    If you're interested, I'll do some more research and get some links to get you started. :-)
    Thanks, and keep up the awesome work! Almost all of Illustrate's products are on my "desert island" wish list. ;-)
    Aaron - aka - volvoguy
    • 46218
    Re: 64-Bit and/or GPU encoding options?
    Someone recently created a flac cuda encoder, there was not a huge difference from a modern processor.
    • volvoguy
      • Nov 2004
      • 17
      Really? That's weird. I know "stats" can be biased, but the audio/video apps that Nvidia is showcasing, show major speedups when using the GPU. Could it be that batch processing vs just one file makes a difference? My understanding is that the GPU can be handy for things like this because of it's parallel processing abilities. *shrug*
      I'd really be interested in testing that build you mentioned if you think the guy would send it to me. You can have him reply here, or email me directly - volvoguy (at) gmail.com
      How about the 64-bit deal? Your thoughts?
      I'm going to try some of the demos Nvidia has posted and see how they work - if only for my own information (but I'll share if you're interested). I "just" have the top-of-the-line iMac right now, but the new workstation I'm researching to build was kinda based around the GPU processing things that Nvidia, Microsoft and Apple are all using. (I think MS's tech is called DirectCompute, Apple's may or may not be open CL - it's too late to think right now).
      Thanks!
      Aaron
        • 46218
        It is being discussed on hydrogenaudio.org
        64 bit would not be a huge speed improvement, but in anycase work is to begin on R14 which will have 32bit and 64 bit native installs, we will be dropping support for Win9x.
        • EliC
          • 1175
          in anycase work is to begin on R14.
          :komisch12 :komisch9: :D
