Show both Accurate and Inaccurate Counts
  • chillburgh
    • Jun 2007
    • 14
    When ripping a disc, show both the number of AGREED CRC checks and DISPUTED CRC checks.
    I seem to have a number of discs with different pressings than those in the database, and it makes sense to have all of the info possible to decide if I have a bad rip or not.
    ex:
    Accurate (12) / Inaccurate (3)
    If every track on the disc has similar numbers then you can feel fairly confident that you have a different pressing, and three other people have the same version.
    Re: Show both Accurate and Inaccurate Counts
    I was under the impression AR does always show counts, accurate or inaccurate. The only time it doesn't show a number is when it is greyed out, which means the track is not in the AR database.
    Do you have a screenshot to show it?
    • chillburgh
      • Jun 2007
      • 14
      I meant at the same time, not one or the other.
      If my CRCs match 5 other peoples, but the majority of users (say, 20) have differing CRCs then that doesn't mean that mine are INACCURATE, just of a different pressing.
      • bhoar
        • Sep 2006
        • 1173
        I think as long as you match *someone* else's rip, you're accurate. So, unless you are the *first* one to accurately rip that different pressing, you'll be Accurate.
        -brendan
          There could be 20-30 different pressings, showing inaccurate would serve no purpose.
