Discussion of dMC R12 Alpha
This topic is closed.
    • 46370
    #451
    Re: Discussion of dMC R12 Alpha
    No, it is not applicable.
    • heavensblade23
      • Oct 2006
      • 14
      #452
      Does R12 not support before-track-one-hidden-audio, or does it just not show up on drives that don't support it? It's not showing anything on a CD that I know has audio there.
        #453
        Not by default, no. There is some way to copy that track, but I forget what it is right off.
        • EliC
          • 1175
          #454
          Thats a problem, especially if Im going to be buying the new reference ver.
            #455
            See here for some tips: http://forum.dbpoweramp.com/showthre...t=hidden+track or http://forum.dbpoweramp.com/showthre...t=hidden+track
            • heavensblade23
              • Oct 2006
              • 14
              #456
              I've been testing R12 for a few months now and basically because of little things like that I've decided to stick with EAC. R12 is missing too many small features that make ripping large numbers of CDs tolerable. If I have to keep EAC around to check for HTOA, I might as well just use it for everything. Same thing with the lack of any ability to fix tags automatically. It might take 2-3 minutes to fix tags in R12 while in EAC I can do in one click.
              • EliC
                • 1175
                #457
                EAC has no problem with hidden tracks. I would hope a pay for version of dMC would not either. I dont usually know most of the CDs well enough to know there is a hidden track until EAC shows it. I dont want to have to manually change setting to find it...
                • Teknojnky
                  • Dec 2006
                  • 323
                  #458
                  FYI, the updated exe for usb c2 support, appears to break c2 support for my firewire burner..
                  The updated stand alone EXE zip:
                  Code:
                  dBpowerAMP Release 12 Beta 4 Digital Audio Extraction Log from Friday, January 12, 2007 9:17 AM
                  Drive & Settings
                  Ripping with drive 'R:   [MAD DOG  - TF-DVDRW TSH652D]',  Drive offset: 6,  Overread Lead-in/out: No
                  AccurateRip: Active,  Using C2: Yes,  Cache: None,  FUA Cache Invalidate: No
                  Pass 1 Drive Speed: Max,  Pass 2 Drive Speed: Max
                  Ultra::  Vary Drive Speed: No,  Min Passes: 2,  Max Passes: 6,  Finish After Clean Passes: 1
                  Bad Sector Re-rip::  Drive Speed: Max,  Maximum Re-reads: 60
                  Encoder: FLAC -compression-level-8 -verify
                  DSP Effects / Actions: -dspeffect1="ReplayGain=-albummode={qt}0{qt}"
                  Extraction Log
                  Track 1:  ERROR Ripping LBA 0 to 4737 (1:03) in 0:02. Filename: J:\Music\Ripped\dbpoweramp\Broken\Broken - 01 - Nine Inch Nails - Pinion.flac
                  Unable to read CD, check CD disc (frame LBA 0  ripping 26 frames   track end LBA 4737)
                  Track 2:  ERROR Ripping LBA 4737 to 21742 (3:46) in 0:01. Filename: J:\Music\Ripped\dbpoweramp\Broken\Broken - 02 - Nine Inch Nails - Wish.flac
                  Unable to read CD, check CD disc (frame LBA 4737  ripping 26 frames   track end LBA 21742)
                  Track 3:  ERROR Ripping LBA 21742 to 43085 (4:44) in 0:01. Filename: J:\Music\Ripped\dbpoweramp\Broken\Broken - 03 - Nine Inch Nails - Last.flac
                  Unable to read CD, check CD disc (frame LBA 21742  ripping 26 frames   track end LBA 43085)
                  The re-installed beta reference installation:
                  Code:
                  dBpowerAMP Release 12 Beta 4 Digital Audio Extraction Log from Friday, January 12, 2007 9:48 AM
                  Drive & Settings
                  Bad Sector Re-rip::  Drive Speed: Max,  Maximum Re-reads: 100
                  Extraction Log
                  Track 1:  Ripped LBA 0 to 4737 (1:03) in 1:31. Filename: J:\Music\Ripped\dbpoweramp\Broken\Broken - 01 - Nine Inch Nails - Pinion.flac
                    AccurateRip: Accurate (confidence 22)     [Pass 1, Ultra 1 to 2, Re-Rip 130 Frames]
                    CRC32: C8F0DE62
                      Re-rip Frame: 640 (00:00:08.533) matched 10 / 10
                      Re-rip Frame: 641 (00:00:08.546) matched 10 / 11
                      Re-rip Frame: 642 (00:00:08.560) matched 10 / 10
                      Re-rip Frame: 643 (00:00:08.573) matched 10 / 10
                      Re-rip Frame: 645 (00:00:08.600) matched 10 / 10
                      Re-rip Frame: 646 (00:00:08.613) matched 10 / 10
                  ....... removed for brevity ........
                      Re-rip Frame: 4651 (00:01:02.013) matched 10 / 11
                      Re-rip Frame: 4652 (00:01:02.026) matched 10 / 11
                      Re-rip Frame: 4653 (00:01:02.040) matched 10 / 11
                  I supect the drive has poor c2 anyway, but the new exe definately breaks c2 for it. Disabling c2 (on the newer exe) enables the disc to be ripped.
                  Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
                  Want a random mode based on track and artist relationships?
                  [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
                  [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
                    • 46370
                    #459
                    That is odd, the fix was to rip in blocks of 13 frames as opposed to 26 (which was causing problems over usb as it is over 64KB). I do not see how ripping less frames should fail on your drive, we will have to see if other reports come in.
                    • Bill41
                      • Nov 2004
                      • 56
                      #460
                      I've been waiting for someone to post this problem, but evidently I'm the only one having it.
                      When I use the right click/edit ID-tag, more often than not, Windows Explorer crashes and I get the error message " Windows Explorer has encountered a problem and needs to close.etc. " Sometimes clicking close on the error message will close the explorer window, but more often it takes the Task Manager to close it, and a couple of times, a hard reboot.
                      This has happened in all the r12 alphas & betas. I have tried redownloading,uninstalling,reinstalling and as a last resort, a clean install of WinXP Pro. I've never had this happen with r11.5. If it's not r12 causing this, then I hope someone out there has a solution to this problem. That said I think r12 will be a great program when finished.
                      Bill
                        #461
                        I had this problem on a few computers and it turns out it was a different right-click entry that another program had put there. Does it only happen on audio files or any files? If it happens on more than just audio files, then dMC is not the problem. If it only happens on audio files, dMC might be the problem, but more investigation is in order.
                        If it is the later, please start a new thread in the Beta forum so that we may dedicate more effort to solving your problem.
                        • Bill41
                          • Nov 2004
                          • 56
                          #462
                          LtData, I'm pretty sure it's r12. It only happens on editing ID tags. The same thing happened when I installed it on a second computer and when I uninstalled and went back to r11.5, the problem went away.Since no one else has reported this problem, I was reluctant to blame r12,but I can't get any other right click option to crash explorer.
                          Bill
                            #463
                            OK. Please start a new thread in the beta forum so that we may investigate this further. Thanks!
                            • anders
                              • Dec 2003
                              • 15
                              #464
                              I was converting some FLAC files into WMA & MP3, so I had two converters running simultaneously. I started the MP3 conversion first, then the WMA conversion.
                              Two files failed to convert in the MP3 conversion, and I clicked on the "re-convert failed" button.
                              The converter came back up with the WMA conversion selected -- seems like it should choose the same conversion settings from the failed conversion, not the last conversion settings used.
                                #465
                                dMC stores the settings from the last conversion in the registry, so it uses those settings when it reconverts. This could lead to the problem you describe, however.
