[codec] 64 bit codec updates - Monkeys Audio, Ogg, Wavpack, etc
This topic is closed.
  • thexfile
    • Jul 2010
    • 177
    Re: [codec] 64 bit codec updates - Monkeys Audio, Ogg, Wavpack, etc
    After installing the CLI I'm getting this box every time dbpa starts. Even if MP3 is selected in 'rip to'.
      • 46171
      Yes you would do, you have to configure the CLI encoder to a specific codec and change the extension (as per help file).
      • thexfile
        • Jul 2010
        • 177
        OK, that did the trick.
        • EliC
          • 1175
          Originally posted by spoon
          cli encoder added
          thank you!
          • thexfile
            • Jul 2010
            • 177
            Looks like ReplayGain may need some tweaking.
              • 46171
              #21
              Update 10th January
              Windows Media Audio 10 added, Ogg Vorbis install updated to include AoTuV encoders.
              • ffm76600
                • Apr 2007
                • 168
                #22
                Hi
                Spoon : Why don't you use an older version of fdk-aac ? the last version is 3.4.12 not 3.3.3
                • ghibliss
                  • Jun 2013
                  • 60
                  #23
                  Is there an expected release date for the 64 bit batchripper? Will all of the current drivers that are included in the v14.3 release also be present in the v15 batchripper?
                    • 46171
                    #24
                    It is likely Batch Ripper will remain 32 bit, if you install to the same location as the 64 bit R15 it will work.
                      • 46171
                      #25
                      AAC encoder added
                        • 46171
                        #26
                        Update 18th February
                        [Replaygain] utility codec - defaults to ebu r128 on and -18 lufs
                          Does this beta contain any fixes related to this thread?:
                          http://forum.dbpoweramp.com/showthre...light=itunnorm
                            • 46171
                            #28
                            No, the final R15 does (it is the mp3 codec which needed the change), it releases very very soon.
                              • 46171
                              #29
                              All Codecs Fully Released
