[codec] 64 bit codec updates - Monkeys Audio, Ogg, Wavpack, etc
This topic is closed.
    • 46221
    These installs contain both 64 bit install (for dBpoweramp R15 beta 64 bit) and 32 bit installs. By default the install will match your dBpoweramp (32 bit or 64 bit).
    AAC Encoder Now Released: http://www.dbpoweramp.com/codec-central-m4a.htm
    CLI Encoder Now Released: http://www.dbpoweramp.com/codec-central-cli.htm
    m4a & m4b FDK AAC Encoder Now Released: http://www.dbpoweramp.com/codec-central-m4a.htm
    Monkeys Audio Release 12 (Monkeys v4.12) Now Released: http://www.dbpoweramp.com/codec-central-monkeys.htm
    Ogg Vorbis R23 (Ogg 1.3.1 Vorbis 1.3.3) Now Released: http://www.dbpoweramp.com/codec-central-ogg-vorbis.htm
    Opus R2 (Opus v1.1) Now Released: http://www.dbpoweramp.com/codec-central-opus.htm
    Wavpack Release 9 (4.70) Now Released: http://www.dbpoweramp.com/codec-central-wavpack.htm
    Windows Media Audio 10 - Release 8 Now Released: http://www.dbpoweramp.com/codec-cent...edia-audio.htm
    Utility Codec - [Arrange Audio] - Release 4
    Utility Codec - [Audio Info] - Release 2
    Utility Codec - [Calculate Audio CRC]
    Utility Codec - [Channel Split] - Release 2
    Utility Codec - [ID Tag Update] - Release 4
    Utility Codec - [ReplayGain] - Release 3
    All Released: http://www.dbpoweramp.com/codec-central-utility.htm
  • thexfile
    • Jul 2010
    • 177
    Re: [codec] 64 bit codec updates - Monkeys Audio, Ogg, Wavpack, etc
    Thank you.
    • EliC
      • 1175
      Please prioritize the 64b CLI and Replaygain for 64b.
        • 46221
        Opus R2 added.
          • 46221
          ID Tag Update R4:
          Includes 64 bit codec
          New external scripting tag option, use VB Scripting to modify tags
          Imported Art designated as Front Cover Art
          File date is not modified by doing ID Tag Update
          Includes new Art option Maximum File Size
          New option Remove Month & Day from Year
          New option Drop Track Count
          New option Drop Disc Count
            • 46221
            ReplayGain added
            • EliC
              • 1175
              ReplayGain added
              Now I'm just waiting on 64bit command line encoder!
              Thanks Spoon
              • ffm76600
                • Apr 2007
                • 168
                Opus 1.1 final release is here
                  • 46221
                  Already in the above list.
                  • Christian_S
                    • Oct 2008
                    • 21
                    Dear Spoon,
                    On my 64-bit Windows 8.1 machine, the codecs install as 32-bit. I have successfully installed in 64-bit Release 15 Beta 8 today, however, any codec or DSP update will only install in 32-bit. Is there a command line switch to for an install in 64-bit?
                    Thank you,
                    Christian
                      • 46221
                      Make sure you do not have the 32 bit version of dBpoweramp installed at the same time, look in C:\Program Files (x86)\Illustrate\
                      There should be no dBpoweramp folder.
                      • Christian_S
                        • Oct 2008
                        • 21
                        Thank you, that did the trick. I uninstalled everything related to the 32-bit installation and manually cleaned the remaining bits in that directory.
                        You instructions for installing the 64-bit R15 implied that it could co-exist with the 32-bit version, perhaps the required cleanup (after saving and copying the .bin files) could be mentioned there as well.
                          • 46221
                          CLI Encoder Added
                          • thexfile
                            • Jul 2010
                            • 177
                            CLI Encoder Added
                            May want to update the link. :smile2:
                              • 46221
                              it was a minimum filter to filter those who are suitable to use it
