Air UPnP (control Airport Express as UPnP devices)
    • 46220
    #31
    Re: Air UPnP (control Airport Express as UPnP devices)
    Currently only one AE is supported from one computer, this relates to an issue in dBpoweramp Renaissance
    • Ralf_s
      • May 2009
      • 40
      #32
      I'm testing the AirPnP very intensiv at different computer (windows XP, 2003 and W7). All the same problem. It runs fine for around 20 minutes, then there came some little breaks. After 30 minutes the AE stops completly playback. Sometimes I must restart the AE, some it's ok to connect and start the stream with the controller.
      Has anyone the same problems or could it a hardware error of the AE?
      Ralf
      • Funkybase
        • Apr 2010
        I are running into some difficulties that I hope that any of you are able to assist me with.
        When I try to send music to air upnp via J river, the air upnp disconnects after a couple of seconds. I have a Netgear 3700 router and I was thinking that I might have to open a port on the router? Have any of you encounter the same type of problem? I have also tried to use the PlugPlayer and NAS with the same problem.
        Kind regards,
        Christian
        • iangrant
          • 94
          #34
          I'm having trouble getting AirUPnP working on Windows Home Server - I have installed it, and the service is running, but Asset Control cannot find my Airport Express. I previously used AirUPnP on Windows Vista and it ran fine.
          I tried running Airport-UPnP-Starter.exe manually on the Home Server and it gave an 'Entry Point Not Found' error with the following message:
          'The procedure entry point DNSServiceGetProperty could not be located in the dynamic link library dnssd.dll'
          Could this be the source of the problem, or is Airport-UPnP-Starter.exe of no consequence?
            • 46220
            #35
            DNSServiceGetProperty is part of Apple Bonjour which should be installed also.
            • iangrant
              • 94
              #36
              Ah, I thought I saw the AirUPnP installer install Bonjour itself, and indeed the Bonjour service existed in the list of Services and was running. Anyway, after installing Bonjour separately (actually Bonjour Print Services...), it works fine now, thanks.
              • iangrant
                • 94
                #37
                Anyone else come across these messages in the Event Viewer logs? (see below: 'DNSServiceResolve active for over two minutes. This places considerable burden on the network')
                After installing Bonjour, Asset and AirUPnP on my Windows Home Server I am seeing it every couple of minutes. If I stop the AirUPnP service, the messages stop.
                Code:
                Event Type:	Error
                Event Source:	Bonjour Service
                Event Category:	None
                Event ID:	100
                Date:		27/04/2010
                Time:		18:54:13
                User:		N/A
                Computer:	SERVER
                Description:
                Client application bug: DNSServiceResolve(AirPort\032Express\032(Office)._airport._tcp.local.) active for over two minutes. This places considerable burden on the network.
                  • 46220
                  #38
                  I have never come across this before, makes you wonder what is generating the error, Mircosoft of Apple?
                  • iangrant
                    • 94
                    #39
                    I know, I've no idea, although I get the impression DNSServiceResolve is part of Bonjour. I tried searching for more about it, but all I could find was stuff for OS X developers. Obviously, I don't get the errors when my AirPort Express is off either.
                      • 46220
                      #40
                      Updated
                      To allow multiple upnp airports from the same computer.
                      • tabulos
                        • Jul 2010
                        what about a password protected airport express? how can i set the password for connecting to this aex? or is this not possible at the moment?
                          • 46220
                          #42
                          Sorry not possible.
                          • tabulos
                            • Jul 2010
                            is this a planned feature or not?
                            • gsi095
                              • Jul 2010
                              Hey,
                              as the AppleTV also can run as an airtunes speaker can it be controlled just like an airport express?
                              Dave
                                • 46220
                                #45
                                You would have to try, I have not tested.
