Cassette conversion
  • cmdr_ashtar
    • Feb 2005
    Cassette conversion
    I have a whole bunch of music in cassette form that I want to convert to MP3. Do I use the same method as LP conversion? I tried with one cassette and when I played the download, although the song was there, there was terrible buzzing sound (like a bad earth connection). Would appreciate any advice.
    Re: Cassette conversion
    Which input socket did you use on the PC? if possible use the line in and adjust the volume on cassette player before the volume on pc.
    • cmdr_ashtar
      • Feb 2005
      Thanks for a speedy reply Spoon. Mine is a Sony Vaio PCG-FX950 (4yrs old)notebook. It has 3 inputs, TV, headphones and mic. I used the mic (stereo) input to download. From the cassette player, headphone out. ?????
        Not much choice, try lowering / raising the volume on the cassette player, also make sure the PC is set to record from the right input (Options >> Input Source).
