How to create Playlists for my NAS (QNAP)
  • tiefrot
    • Aug 2018
    Hi all
    Since having my NAS I try to create Playlists (m3u) to play some music on my receiver. However, I did not find the correct way to do it.
    This is my hardware config:
    1x NAS from QNAP with movies, MP3s and FLACs
    1x Yamaha Receiver (Yamaha RX-A2020) for streaming music
    1x PC (Windows 10 Pro) for creating the Playlists on my NAS
    I think the problem is based on the file structure on my NAS. Is there any good tool to use for it? I will not capitulate on modern software.
    And last but not least. Is there a way to create some playlists for FLACss too? But this is just a secondary issue.
    Best Regards from Leipzig (Germany),
    Marcus.
    • 45856
    Re: How to create Playlists for my NAS (QNAP)
    See:
    The Playlists that I create with Windows Media Player are not working on my QNAP NAS. I am running Asset UPnP version r6.1 on my QNAP (trial edition) My Music files are on /Shared/FLAC Library/ Windows Media Player sees the files fine and creates .m3u playlists in the folder /Shared/Flac Library/Playlists. The playlists
