ape to flac problem
  • Tonyrieko
    • Aug 2017
    ape to flac problem
    Hi all this is my first post.
    I followed the steps to convert an APE file to FLAC. It only took 2 seconds to finish. It produced an output FLAC file but it was only 3325KB compared to the original APE file size of 570,555 KB and only played for 3 seconds or so.
    System = Windows 10 Pro
    DB Poweramp version = 16.2 64-bit.
    Can anyone suggest what’s happening please?
    Tony
    • 46160
    Re: ape to flac problem
    The ape files seems quite large, what created it? and can you play it in other players?
    Are you able to try other ape files?
    • Tonyrieko
      • Aug 2017
      Hi thanks for the answer. I don&*8217;t know how large an APE file usually is. I downloaded some Indian music; it&*8217;s an album that I used to have on cassette. In the folder that I downloaded, there are 2 APE files, presumably each contains half of the album. It will play ok on GOM Player. I don&*8217;t have any other APE file to try.
      Cheers
      Tony
