Problem with moving/deleting directories/files after Ripping
  • RvK
    • Sep 2015
    Hi Experts,
    i formerly ripped with EAC and it was too slow in action. Then I bought dBPoweramp and now i'm using dBPoweramp CD Ripper. I'm ripping with my notebook with internal and an external drive.
    It's very quick and working really accurate.
    But I have problems moving or deleting directories after ripping. There are messages that files are opened in another process. I think the "Thumbs.db"-Files could be the reason.
    I believe it is a known problem but i didn't find helping posts. Do you have a solution for this behaviour?
    Thank you for your Help .
    • 46376
    Re: Problem with moving/deleting directories/files after Ripping
    Thumbs.db is the Windows thumbnail database, it is at the system level.
    • RvK
      • Sep 2015
      Hi Spoon,
      thx for your answer. That is correct.
      I'm astonished because i used the same directories with EAC. And there was never a problem to move new ripped files from the "Working-Directory" to the complete "Flac-Archive-Directory".
      There must be a difference when directories during ripping is created.
      Best Regards
        • 46376
        Perhaps dBpoweramp is embedding the album art, it also extends the Windows Thumbnail providers so that the embedded art is shown in Windows explorer.
        • RvK
          • Sep 2015
          Hi Spoon,
          I disabled the function "save data in hidden Thumbs.db" via GPEDIT.MSC (using W7 Pro). Thumbs.db are History now. Everthing is working fine now.
          Best Regards
