Temporary fix for 2 computer problem.
  • patrickc
    • Dec 2014
    I installed dbPoweramp on my old HTPC in 2012 only to replace it with a new high end HTPC from a well respected builder. While I never used dbP on my old HTPC, I didn't install it on the new HTPC because it turned out to be the HTPC from HELL, literally almost unusable for a year and a half.
    Today the old HTPC is in my office with as much trimmed from the smallish hard drive as possible. I recently purchased an SSD that will help with the space problem.
    So now that the main HTPC is deemed usable and I haven't found time to install the SSD (which will test my computer skills) on the old HTPC, I would like suggestions for putting dbP in limbo for a few weeks. It's by far the biggest program on the hard drive. Still not having used the program, I know very little about it. The old HTPC is extremely slow at this point but used daily for odds and ends. If I could transfer dbP to an external hard drive or thumb drive to save space until after the first of the year, that would help a lot. I could then take my time installing the SSD on the old HTPC and re-installing dbP on my newer HTPC finally.
    Old newby needs help.
    Patrick
    Re: Temporary fix for 2 computer problem.
    One can always simply reinstall dbpa from scratch. You can redownload your purchased install from illustrate (you need your original order number or there is also a way to get that with your email address).
      Visit:
      to download the registered version.
