Tag editor problem with iTunes
  • fedunator
    • Nov 2012
    Hi folks, first time poster here. first of all, awesome soft. now the problem: i just edit the tags of all my library and for some reason iTunes dosen't recognize the year tag. thanks very much.
    Re: Tag editor problem with iTunes
    Which audio format are you using?
    • fedunator
      • Nov 2012
      sorry... all mp3 files, OS: windows 8 32 bits. thanks
        If you are using R14.3 you need R14.4:
        • fedunator
          • Nov 2012
          i did install R14.4, edit a couple of tags and refresh iTunes library... but still :(
          Uploaded with ImageShack.us
            Sorry what am I looking at? I see the year is shown as 1990 for both property boxes.
            • fedunator
              • Nov 2012
              yes, do you have any idea why iTunes dosen't show it?
              also: i uninstalled dbpoweramp and windows doesn't recognize various tags
                If you have tagged a file with R14.3, then you need to change the year value for it to be written correctly in R14.4, try changing 1990 to 1991
                • fedunator
                  • Nov 2012
                  YAY this means that i only need to re-entry the year of each album of my library, thanks you so much.
                    Or install the [ID Tag Update] utility codec (from Codec Central) then batch Convert all the files to this, it rewrites all the ID Tags.
                    • fedunator
                      • Nov 2012
                      you magnificent bastard, thank u so much for the support. love your software
