Custom Fonts CD ripper
  • danlollar
    • Jun 2012
    I'm totally loving dbpoweramp!
    But I have a question.
    Is it possible to use custom fonts in the metadata?
    I understand some media /MP3 players may not recognize the format, but if I have the font loaded on my hardware can I change the default font to use the die nasty font for when I rip my KISS CD's?
    Thanks for any input/suggestions.
    Re: Custom Fonts CD ripper
    It is not possible to change fonts in hardware players.
    • danlollar
      • Jun 2012
      Sorry for using wrong terminology.
      I meant if the font is available on my home network is it possible to the use custom fonts when ripping to my server.
      I'm using JRiver Media Center at the other end of this.
        If you install all the language packs you can type ID tags in any locale (for example Chinese), if the tagging format supports unicode it will be stored correctly for the player to show, then it is down to the player.
