Removing .m4a conversion leftovers
  • ilduro
    • Dec 2009
    • 9
    After batch converting thousands of .m4a files into flac, my directories are polluted with the files I actually wanted to get rid of - and some more. There seems to be no option to batch delete them and none of the traditional Windows methods are working. Help, please!!
    Re: Removing .m4a conversion leftovers
    Please clarify 'and some more'
    • ilduro
      • Dec 2009
      • 9
      These would be files named ._08xxx.m4a or .DST_STORE or ._.DST_STORE. Not sure they were created together with the conversion. I see them on the Windows box but not on the mac so I am not terribly worried.
      The remaining .m4a files are my greater concern as they don't let Chorus DS read the metafiles of my .flac files.
      For future conversions, is there a way to avoid keeping the original files so that only the converted new files would remain in the directories after the conversion?
        There is a DSP Effect 'Delete Source file' use it carefully.
        • ilduro
          • Dec 2009
          • 9
          Many thanks, Spoon. So far it has been working well. For security, I always do backups first. Happy Holidays to you!
