Problem with Cds
  • simonp51
    • Dec 2010
    Problem with Cds
    I am a new user of this program. I am using it because since we bought a new laptop operating Windows 7 I have bought a number of new CDs which wouldn't import properly into itunes & someone suggested using dspower to rip them first before copying into the music library.
    Unfortunately though it seems so far that this program is struggling with the same Cds that itunes struggles with, certainly if I just insert the CD and start ripping.
    I confess I am not very technically minded & wonder if I need to change settings in some way to enable the CD to be read. (I've tried all this in itunes already without success.) Is this a problem that others recognise? I do find it hard to believe that I am the only person buying problem Cds but I have been told that some CDs are now designed so they can't be read by a computer, so if so I'll just have to buy the digital versions instead in future.
    I hope I've set out the problem clearly & would appreciate any guidance.
    Regards
    Re: Problem with Cds
    If iTunes and dBpoweramp both cannot read the audio CD it is safe to say that your CD Drive + CD combination cannot read the disc. Sometimes different makes of DVD drive can read discs other drives cannot.
    • simonp51
      • Dec 2010
      Thanks for reply, it makes sense sadly. Seems odd though that it's only happened since we bought the Windows 7 laptop.
