Need help installing M4a codec
  • Jckinnick
    • May 2010
    Im trying to install the m4a codec by following the instructions on the page below.
    file:///C:/Program%20Files/Illustrate/dBpoweramp/Help/Codec/mp4/Help.htm
    The part im having trouble with is this part.
    " 2) Open the zip file (by double clicking on it) and open the folder win32, select neroAacEnc and copy (Edit menu >> Copy). Open a new explorer window, it is important the old zip window is left open (press Windows Key + E) and browse to:"
    When i try and open the file by double clicking it so i can copy and paste it disappears to quickly for me to go in and do the edit menu>> copy part.
    How can i get it to stay and quite disappearing when i double click the file called neroaacenc.
    • 46164
    Re: Need help installing M4a codec
    You do not double click it, rather right click on the neroaac and select copy.
    • john_barrett
      • Jun 2010
      Thank you, I had the same problem, now solved.
