iTunes does not recognize wav tags?
  • todd
    • Mar 2010
    When importing ripped .wav files from dBpoweramp, none of the metadata or album art are recognized by iTunes.
    Win7
    dBpoweramp reference
    iTunes 9.0.3
    ripping .wav with default settings
    Also tried MediaMonkey with similar results
    The tag info does show up in Windows Explorer
    Have tried many different things including tag settings, file naming, etc.
    Is there some way to tweak dBpoweramp to improve this or is it just a limitation of iTunes?
  • Wayne
    • Aug 2002
    • 1254
    Re: iTunes does not recognize wav tags?
    iTunes doesn't support tags in wav files.
    • schmitty
      • Mar 2010
      • 47
      WAV files in general don't support ID3 tags, as far as I know, it's something that dBpoweramp does. It's a good idea, I think ID3 should be made a standard for tagging across all audio file formats
      Schmitty
      • cexuit
        • May 2010
        There are several tag types that can be embedded within WAV files. The most common is INFO LIST, supported by tools like MediaMonkey and MetadataTouch. There are few tools that support ID3 for WAV, such as MusicMatch Jukebox and mp3Tag Pro.
