audio files as 8bit 8KHZ u-law format
  • ang
    • Mar 2010
    Hi
    I need to create some audio files as 8bit 8KHZ u-law format.
    I believe I can do this using DB power amp?
    Do you know in which format should I record the files? Would a WAV at 44khz suffice and then I convert to the required specs after or would this cause distortion to the file?
    thanks
    Ang
    Re: audio files as 8bit 8KHZ u-law format
    Sorry not supported.
