DTS Audio CD
  • jz6pwc
    • Jan 2010
    DTS Audio CD
    I have a few DTS 5.1 Audio CD's. (ie. The Police - Every Breath You Take) that I would like to rip to FLAC and/or Apple Lossless. The issue is all I hear is noise. Even when I use the play button on the rip tool. I believe that means I do not have a codec to play the audio with.
    Please advise on if there is one in "Codec Central" that I need to use or how to accomplish a successful rip.
    Re: DTS Audio CD
    Normally you would feed the digital out of the PC to a AV decoder which would decode and supply the 5.1
    • jz6pwc
      • Jan 2010
      Re: DTS Audio CD
      I want to rip it. It will play thru VideoLAN, and I could save the stream that way, but its not ideal. If VideoLAN can play it there must be something out there that will do this....
        Re: DTS Audio CD
        You need a DTS decoder. dBpoweramp will decode if the wave file has a DTS format header and you have the DTS ACM codec installed.
        • jz6pwc
          • Jan 2010
          Re: DTS Audio CD
          Well, I'm on windows 7 and have the shark007 codec pack installed. it includes ffdshow... however, it maybe the header is missing because I never see the ffdshow icon in the tray when attempting to play or rip.
