how to convert from flac level 8 to flac level 0...
  • jarthel
    • Oct 2008
    without having to overwrite the original file and the destination folder is the same as the source folder.
    I was hoping like this is possible:
    original file: 01. track1.flac
    new file: 01. track1 1.flac
    or something like that.
    thank you very much
    • 46160
    Re: how to convert from flac level 8 to flac level 0...
    You can use Dynamic naming with
    [origpath]\[origfilename][unique]
    • jarthel
      • Oct 2008
      I tried the suggestion and I did not see any new files in the source folder.
      If I use "original folder" as output location and use WMAL as output format, it works fine.
      any other ideas?
      thank you
        • 46160
        Click List / Rename button at the top to show where the files are going.
        • jarthel
          • Oct 2008
          the source is d:\music\temp. According to List/Rename, the destination is "music\music\temp" (take note the lack of drive letter in the destination).
          could this be a bug?
          thank you
          update: I just checked and it seems the files goes to the music folder inside my documents.
          another update: it seems "dynamic naming" uses the location specified in "folder". I thought "folder" and "dynamic" are separate settings without any relationship to each other. This isn't the case.
            Dynamic naming first uses the root specified in the Folder path and builds off of it.
            • Falco98
              • Feb 2009
              out of curiosity, why would you want to convert from level 8 to level 0?
