How do I configure DBPA for hard to rip CDs?
  • Transporter
    • Nov 2008
    • 9
    I have run the two tests on my current drive. It passed both and said they were available as an option. So I have both "Clear Read Cache w/ FUA" and "C2 Error Pointers for Error Detection" enabled. My drive passed the accurrip test and has an offset assigned.
    How should I configure DBPA for the most successful ripping?
    I have a few CDs that get full blown errors and the tracks don't rip, not even to insecure. Thoughts/Suggestions?
    • 46226
    Re: How do I configure DBPA for hard to rip CDs?
    What are your drives?
    • Transporter
      • Nov 2008
      • 9
      Current drives are HP dvd 840 and Plextor PX-W4012TA
      Can you recommend the best drives?
      Best internal EIDE
      Best internal SATA
      Best USB
      Best evternal SATA
        • 46226
        The HP for sure will not have the FUA cache disable. Perhaps even the Plextor you have (it is old).
        • Transporter
          • Nov 2008
          • 9
          I did the test inside of DBPA and it said it passed the FUA and checked the box. Is it possible to pass and not reallt be able to disable the cache?
            • 46226
            Yes
            • Porcus
              • Feb 2007
              • 792
              First: If they are "defective by design" -- those pesky copy-protected quasi-CDs -- then you must expect errors if you are not using the DbD mode (or maybe Burst).
              If the CD is too badly scratched, then if all else fails, try Burst -- or even the DbD mode there too.
              The thing about "secure" ripping with error pointers, is that it will dig deeper into the matter to (i) detect and (ii) correct errors. Now the downside is that (i) might discover errors which are truly unrecoverable, but which dBpoweramp would not notice in a burst rip. Hence *if* there are unrecoverable errors -- in which case a "secure" rip is indeed out of the question -- then burst *may* be a better choice, simply because it won't try to achieve the impossible and you might be better off with an incorrect rip interpolated, than with an error resulting in no file.
              To wishlist: an option to "fallback to Bursting over unrecoverable errors".
