How do I fix naming and tagging problems
    • 46226
    Re: How do I fix naming and tagging problems
    Install the Utitlity codec 'Audio Info' convert that mp3 file to [Audio Info] and enable the extensive fields option, post the results here please.
    • texasflood
      • Jul 2008
      • 58
      Hope this is what you need. The 1st one is file which I didn't type in Disc #, the 2nd one I did.
      Audio Details for: C:\Users\Jeff\Music\Gilels, Emil\Historic Russian Archives; Emil Gilels Edition\Emil Gilels - Historic Russian Archives; Emil Gilels Edition Disc 7 - 01 - Morceaux (6) for piano, Op. 19; 1. Reverie du soir.mp3
      Length: 4 minutes 6 seconds
      Channels: 2 (stereo)
      Sample Rate: 44.1 KHz
      Sample Size: 16 bit
      Bit Rate: 107 kbps
      Audio Properties:
      Audio Quality: Medium (Lossy)
      Encoder: LAME 3.98
      Encoder Settings: Variable Bit Rate -V 2 (Standard)
      Channel Mapping: Left, Right
      Channel Coupling: Joint-Stereo (Mid Side)
      Sample Count: 10,855,068
      MPEG Version: MPEG 1 Layer III
      MPEG Technical: Header: Lame [delay: 576 padding: 1956] Bits: Original
      ID Tag: ID3v2.3 (UTF16)
      Contains: Album Art, ID Tag [ID3v2.3 (UTF16)]
      Gapless: Yes
      ID Tags:
      Composer: Pyotr Il'yich Tchaikovsky
      _albumart_1_Front Album Cover: DATA Length: 17354 ......JFIF.....`.`..
      Artist: Emil Gilels
      Label: Brilliant Classics: 92615
      Title: Morceaux (6) for piano, Op. 19: 1. Reverie du soir
      Album: Historic Russian Archives: Emil Gilels Edition
      Album Artist: Gilels, Emil
      Genre: Keyboard
      Year: 2005
      Disc: 07
      Track: 1
      Rating: 8
      Length: 246146
      AccurateRipResult: AccurateRip: Accurate (confidence 4) [AE69068F]
      AccurateRipDiscID: 017-0032220f-027e333b-f7126b11-1
      Encoded By: dBpoweramp Release 13.1
      Encoder: [Audio Info]
      Encoder Settings: -extensive
      Audio Details for: C:\Users\Jeff\Music\Busch Quartet\Beethoven; The Late String Quartets, Disc 1\Busch Quartet - Beethoven; The Late String Quartets, Disc 1 Disc 1 - 01 - String Quartet No. 12 in E flat major, Op. 127; Maestoso - Allegro.mp3
      Length: 6 minutes 52 seconds
      Sample Size: 16 bit
      Bit Rate: 104 kbps
      Audio Properties:
      Audio Quality: Low (Lossy)
      Encoder: LAME 3.98
      Sample Count: 18,171,552
      MPEG Technical: Header: Lame [delay: 576 padding: 1824] Bits: Original
      Gapless: Yes
      ID Tags:
      Composer: Ludwig van Beethoven
      Artist: Busch Quartet
      Title: String Quartet No. 12 in E flat major, Op. 127: Maestoso - Allegro
      Album: Beethoven: The Late String Quartets, Disc 1
      Album Artist: Busch Quartet
      Genre: Chamber Music
      Year: 2008
      Disc: 01
      _albumart_1_Front Album Cover: DATA Length: 9790 ......JFIF..........
      Track: 1
      Rating: 9
      Length: 412053
      AccurateRipResult: AccurateRip: Accurate (confidence 2) [A8C435D4]
      AccurateRipDiscID: 011-00248a47-01321c5d-9012830b-1
        • 46226
        Disc is definately there, so do not know why said programs cannot see it.
        • texasflood
          • Jul 2008
          • 58
          I can't figure it out. I was just trying to save some typing time, but I also have to manually type in the album artist name too, because unchecking the xxx, yyy to yyy xxx box doesn't work either, so it's no big deal. AMG usually already has the disc # included in the album name anyway, so I'd have to erase it if this function did work or the disc # would be there twice. Anyway, I prefer this program to EAC, and foobar is WAY to complicated to even waste my time trying to figure out.
