How to remove Track Gain from MP3
    Re: How to remove Track Gain from MP3
    Originally posted by Dropbear
    I'm finally going through my Archived Music Collection which has a lot of very old MP3 files that cause errors when re-processed. They play ok, but have errors in their headers (and sometimes [but rarely] with corrupted tags).
    What errors are you getting and in which application? I downloaded your mp3 and it appears fine.
    • Dropbear
      • May 2020
      • 57
      Yep. Thanks mville. I've done a little bit more thinking after I posted this torrent of posts. lol. Sometimes it helps me get my thoughts around an issue. I might mull this project over for a while, before I get back here. I might be getting too hung up on the small details. I realize I'm doing things in a non-standard way. Ideally for me, (and probably only for me) by processing Music videos and regular music files in the same batch process, the 2 dBpoweramp Converters would be combined into 1 super Converter that handles both Video & Audio files perfectly, as they do separately, but alas that probably won't happen, so I need to work around that.
      The MP3 file I uploaded does appears perfectly fine, and the replaygain_track_gain setting technically should be there as it is. It's just that I wanted to be able to clear it out, for my project. Anyway I've found a way to do that now, so all's good.
      • Dropbear
        • May 2020
        • 57
        Just some useful info for those who might also want to cut the "replaygain_track_gain" pseudo-tag from their original MP3 files.
        I used this small program called "mp3DirectCut" from mpesch3.de together with lame_enc.dll from rarewares.org/mp3-lame-bundle.php
        Note: You must use the 32-bit version of lame_enc.dll, otherwise the program will tell you that it can't find it, instead of telling you that it's not compatible. That caught me out when I used the 64-bit version !
        Just load your MP3, (it also supports drag & drop) and from the "File" menu select... "Save complete audio..."
        It did the job of removing the ReplayGain info from the MP3 header.
        Works a treat. No re-encoding occurs, and all Metadata is retained. Only the LAME headers are modified. Perfect !
          • 6189
          Nice tip. Thanks!
