How do I configure db cd ripper 12.1 to automatically rip cd when inserted?
    Re: How do I configure db cd ripper 12.1 to automatically rip cd when inserted?
    I edited your first post with the incorrect code to show that you had put the correct code below.
    • bhoar
      • Sep 2006
      • 1173
      Thanks. I'll probably have some more changes over the weekend. I'll try to bundle them into a single post this time.
      -brendan
        If you can't edit any posts, just say so and one of the moderators can edit the post for you.
        • scoughlan
          • Dec 2007
          • 9
          I see this is an old post (2007) and would like to know if the auto-rip is included in version 12.4? I would like to use CD Ripper to batch convert CDs on a Linux distribution (Linux support via Wine not listed for Batch Ripper). Is this possible now? Or, can anyone make it work by scripting? Thanks for any help.
            Batch Ripper would work under Wine I am sure.
            • Remo
              • Aug 2009
              Hi
              I have downloaded the latest versions from the website and I am still having the same problems that it wont auto start ripping. I have checked all the info from the webby and I dont think I have done anythign wrong. Any ideas?
              I would like to see a basic quick start, fool proof setting guide for a single or twin draw manual loadding auto eject setting. Can anyone help?
              Remo
                See:
                • Remo
                  • Aug 2009
                  Thanks Spoon but thats where i came from and nope it still does not want to auto start rip, hence my post if there can me more info id appreciate it. FYI I have read all previous info available before posting.
                  • Teknojnky
                    • Dec 2006
                    • 323
                    #24
                    I am still waiting for auto-rip in the main ripper.
                    Want to see [url=http://www.last.fm]Last.FM[/url] relationships using your own library?
                    Want a random mode based on track and artist relationships?
                    [url=http://www.mediamonkey.com/forum/viewtopic.php?t=24879]Try Last.FM Node[/url] for [url=http://www.mediamonkey.com]MediaMonkey 3![/url] ([url=http://img178.imageshack.us/my.php?image=lastfmnodemediamonkey3fj3.jpg]screenshot[/url])
                    [url=http://www.last.fm/user/teknojnky/?chartstyle=Geldropdown-small][img]http://imagegen.last.fm/Geldropdown-small/recenttracks/teknojnky.gif[/img][/url]
                      You have installed the batch ripper? and are using Batch Ripper?
                      • Teknojnky
                        • Dec 2006
                        • 323
                        #26
                        Me? Yes I have batch ripper.
                        Let me be more clear, I want to auto-rip without requiring the use of batch ripper.
                          The question was aimed at Remo.
                          Normal CD Ripper cannot auto-rip our metadata providers would never allow it.
                          • Teknojnky
                            • Dec 2006
                            • 323
                            #28
                            Thats a pretty ridiculous restriction, particularly when your metadata providers are optional to the user and many other ripping applications (which may or may not use the same metadata) include auto-rip options.
                              We wrote a whole auto-ripping program called Batch Ripper where the metadata can be selected on or off.
                              • Remo
                                • Aug 2009
                                Sorry Spoon been away a few days,
                                Yes i have both installed and was using the batch ripper, i did it several times including 2 re-installs. I will be trying on a different pc today will get back to you. This is important as we may be conacting you regarding a commercial venture with you
                                Regards
                                Remo
