lets talk mdfs
  • yassir
    • Jul 2005
    • 11
    lets talk mdfs
    hey peeps,
    i have this problem which is i have a ps2 game on my pc and bascially there are just two files, .mdf and .mds and bascially mdf is a huge 4gb file whilst the other is about 4kb so when i load the mds(small one) it loads the mdf but on a dvd burner ready to burn . so i burnt it but it didnt work on my ps2 so i just wanna ask, do i take the .bin file out of the .mdf and burn that because the mdf files has some other files too(small ones).
    P.s, i am only used to burning .iso files and they work fine...
    THANx
  • yassir
    • Jul 2005
    • 11
    Re: lets talk mdfs
    P.s Whilst Waiting For An Answer I Have Extractyed The .bin File Out From The .mdf And Nero Doesnt Alow It To Burn As An Image.
    So I Have No Idea What To Doo.......
    • Wayne
      • Aug 2002
      • 1254
      Re: lets talk mdfs
      Aren't .mdf and .mds files created by Alcohol 52/120?
      Alcohol 120% has the ability to burn these files to CD/DVD. Alcohol 52% can't burn files but instead it can be used to mount the files as a virtual drive so that it could be copied using something like Nero.
      Alternatively a quick google showed me that you could also try MagicISO.
      How did you obtain these files? Did you create them yourself?
      Wayne
      • yassir
        • Jul 2005
        • 11
        Re: lets talk mdfs
        nah wayne i downloaded them as 1 .rar file then just extracted them
          Re: lets talk mdfs
          Have you tried using the programs he suggested, alcohol 120% or MagicISO, to burn these files?
          • Wayne
            • Aug 2002
            • 1254
            Re: lets talk mdfs
            Has your PS2 been chipped so that it can play home burnt games?
            Wayne
            • gameplaya15143
              • Sep 2005
              • 276
              Re: lets talk mdfs
              mds/mdf is an alcohol 120% image
              if you are going to burn it to disk, use that
              if you dont have a mod chip installed on your ps2, it wont work
              (apparently there are ways around not having one, but you'll have to do some research for that)
              • yassir
                • Jul 2005
                • 11
                Re: lets talk mdfs
                hey ppl thxxxx to ever1 who posted in this thread.
                YES i used alcohol and..It worked so thank you to every1 and i think ill stick with alcohol now.
                cheers
