is it possible to get an asx converter that converts a whole album instead of single files?
Asx Converters
Asx Converters
Tags: None -
Re: Asx Converters
Are you wanting to create such an .asx file or decode/convert such a file?
.asx is a meta-file format that is comprised of audio and/or video files. It Could contain only one or a few such files or it can contain a full albums worth of tracks, possibly with other content as well. Generally you should be able to play such a file but converting may be a bit more difficult. Please refer to the FAQ on meta-files (includong .asx) by ChristinaS. here:
See also the following thread regarding .asx and .m3u files (especially Christina's comments and recommendations in the 3rd post of the thread):
Bill
