yooo .I wanted to know if i could network to pcs using a wire which had a usb end on both sides and connect one end on each computer. could i share files that way? has anybody tried it? thanks
					networking...
	Tags: None
 Re: networking...
 I've tried in the past. No, I didn't have success... I think you need a router to connect the computers to each other...
 Wait Yas. I might be wrong, since I dont' have much experience with networking. Wait for more replies.
 Re: networking...
 You CAN connect computers together with USB, but only for USB cables specifically designed to due so. Just a USB cable with the correct ends will not do it, as it requires a piece of firmware to mediate between the computers to network them in this manner.Comment
 Re: networking...
 Here is one example of such a device: http://catalog.belkin.com/IWCatProdu...oduct_Id=20963
 Its called Belkin's "USB Direct Connect" device.Comment
 Re: networking...
 Actually, I'm SURE that USB is faster. Just walk into a Staples or an Office Depot, go under the "Networking" aisle and look at the specifications for the two different cables.Comment
 Re: networking...
 However, IIRC, the cable length limit is shorter for USB than it is for ethernet. Your best, relaible bet for networking two computers is an ethernet cable. Note that if you are not using a switch, hub, or router, you need a special ethernet cable called a "crossover cable" that allows you to directly hook two computer together.Comment
 Re: networking...
 (12:49:46) Neil the Cellist: hiya
 (12:49:59) LtData: hi
 (12:50:06) LtData: brb real quick, testing something
 (12:50:10) Neil the Cellist: how fast is ethernet? 480 mbps? how fast is USB 2.0?
 (12:50:11) Neil the Cellist: oh ok
 (12:51:02) LtData: ethernet is either 10mbps or 100mbps
 (12:51:06) LtData: USB 2.0 is 480mbps
 (12:51:12) LtData: note that all of these are maximums
 (12:51:13) Neil the Cellist: so USB is faster
 (12:51:20) LtData: yea
 (12:51:25) Neil the Cellist: o s*** I lied to Smoggy then.  Comment
