Re: RE: You Tube Grabber (help?)
  • monsterjazzlick
    • 1764
    Hi folks,
    Earlier this year I purchased the full version of video grabbing/converting software 'WinX Ripper':
    It is fine and I am very happy with it.
    One of my intended uses is to grab (from You Tube) rare Jazz recordings which are not available for purchase (or are being advertised on the likes of eBay at ridiculously hiked-up prices of circa $200!).
    For example, I stumbled across an amazing Chick Corea album from the 70s called 'The Sun'. I have d/l it to my PC using 'WinX' s/w:
    Now, because it is a video (well, an MP4 with some cheesy still images added by the OP), I need to extract the AUDIO. And so I drag&drop the MP4 into 'WinX'.
    My question is, please, I am offered a few different formats such as: WMA, MP3, FLAC, WAV, etc (I am on PC). There are comments (eg. recommendations) underneath each format:
    I am assuming that when a music file (say a WAV) is uploaded to You Tube (by the OP) that it is automatically converted (by Google) into an MP3 file? If so, or if similar, then is there any point in me converting the audio from the grabbed video into FLAC or WAV? I mean, will I just end up with a large file size but nothing gained 'audibly' speaking?
    Many thanks,
    Paul
    Last edited by monsterjazzlick; November 10, 2017, 05:31 PM. Reason: Insert Images
  • Jailhouse
    • Sep 2016
    • 388
    Re: You Tube Grabber (help?)
    I imagine obtaining a recording this way as illegal in the UK as it is in the US. Scarcity or unavailability of the source doesn't change that.
    That said, if the streamed audio is in MP3 format, converting it to FLAC will result in a file that sounds like an MP3. It might make your tagging easier, though, since you're ripping your CDs to FLAC. With the FLAC option available, I wouldn't convert to WAV at gunpoint.
    • monsterjazzlick
      • 1764
      Hi JH,
      Yes, I agree it is a a little shady to download albums from You Tube which results in the artist receiving zero royalties. But I can't afford $200 for a s/h vinyl! If I have any defence at all here, I just checked to find I have over 40 x Chick Corea albums (around 13GB) so I have spent quite a lot of money on him. Plus, I have been to see him perform in London 7 x times. Anyway, he donates 25% of his income to L.Ron Hubbard's 'Church Of Scientology'! lol
      I am actually not sure which format the You Tube upload is in?, or how you might be able to tell:
      All of my own uploads are MP3s. I did try WAV a few times but they took too long to upload!, plus someone said that they are converted (by Google) - but I can't remember what to?
      Yes, FLAC is best for tagging over WAV.
      Cheers,
      Paul
        • 6189
        I don't know enough about youtube to know what the format the audio is stored in. And I don't know how your program handles saving audio. Here's the potential problem I see. Say the youtube is mp3, then your program extracts the audio as mp3, but it is actually *converting* the existing audio to mp3. This could result in a transcoding of a lossy mp3 to mp3 again (this is generally a no-no). Extracting as FLAC probably means that at least you haven't done a transcode from lossy to lossy. The extracted audio is whatever is is (even if mp3). Given that, I'd likely go with FLAC. And even though it may be wasted hard drive space, how many of these are you really going to have. Hundreds? Probably not. So what's a little wasted space on a HDD....
        • monsterjazzlick
          • 1764
          Hi Gary,
          Thanks very much.
          So you mean that 'Win_X Converter' would be converting a music-file to exactly the same file type as it already is?!
          In any case, I have d/l as FLAC.
          It is only the ultra rare, unobtainable, and mega expensive recordings that I plan to grab from You-Tube. Possibly about 10 albums at the absolute most. I use You-Tube to audition CDs I am interested in hearing, and then if I like them I order them from eBay or Amazon. Most single CDs are under $10 which is an OK price.
          I can't remember if I told you but I am studying English and Maths on a part-time evening class, as a mature student. And so I purchased 'WinX Converter' to d/l tutorial videos from You-Tube and store them on my Amazon Tablet (so that I don't have to be online to watch them). None of the videos are for-sale products and so I am not causing any Party to lose revenue. They are solely for personal study purposes.
          Paul
            • 6189
            I have no knowledge of how "Win_X Converter" works. But it is *not* unlikely that it may reconvert any youtube audio, even if converting from, say, mp3 to mp3. Given your use case, I'd go with FLAC, then you know you have at least the same quality as the original youtube video.
            • monsterjazzlick
              • 1764
              Hi guys,
              Now that I have d/l the You-Tube recording of Chick Corea's 'The Sun' CD, I have a couple of questions if I may.
              The d/l is the full album, albeit with no track-markings! In other words, it is one continuous track from start to end:
              Is it possible, please, to use Illustrate to create separations (ie. Track 1; Track 2; Track 3; etc)? I had a try earlier and (I probably totally off here!) I was thinking you might be able to BURN the file to CD, and then open the CD with 'dBpa', and perform the task using the latter s/w?
              Or, can you only achieve the desired end result using a different s/w altogether? I have the DAW 'Steinberg Cubase' (which I use to record my own songs on). This would be able to make the edits in; but I was interested to hear if Illustrate was capable? 'Cubase' has much capable tagging facilities for MP3, and some for Wav; but I don't think they are a match against Illustrate.
              Cheers
              Paul
              • monsterjazzlick
                • 1764
                Cheers Gary. That's really helpful. I have followed your advice here. Paul
                  • 6189
                  Hi guys,
                  [ATTACH=CONFIG]1837[/ATTACH]
                  Cheers
                  Paul
                  no, not possible with illustrate products. But there are products that allow you to edit an audio stream into separate parts. Something like audacity will do what you want.
                  Audacity is the world's most popular audio editing and recording app. Edit, mix, and enhance your audio tracks with the power of Audacity. Download now!
                  • monsterjazzlick
                    • 1764
                    http://www.audacityteam.org/
                    Cheers Gary,
                    I have heard of 'Audacity' before on different forums.
                    Do you use it yourself?
                    Paul
                    (Have just d/l.)
                      • 6189
                      Cheers Gary,
                      Paul
                      (Have just d/l.)
                      Years ago I used it to create a bunch of short song clips to use as ring tones on my phone.
                        If you have Cubase, I would edit in that, rather than install more software.
                          • 6189
                          Yes. And once you break into separate tracks with cubase, you can use dbpa to add tags and artwork.
                          • monsterjazzlick
                            • 1764
                            Hi mville,
                            I only have Cubase on my work PC. I have installed Audacity on my home laptop now. It only took a couple of minutes. I will see how I get along with it. I can always use Cubase instead if preferred.
                            Paul
                            • monsterjazzlick
                              • 1764
                              I watched some tutorials on 'Audacity' and tried to make the CD edit using only this s/w.
                              I split the tracks and exported. But even though all of the tracks are correctly numbered (1-5), they only appear in alphabetical order (rather than by respective track number?):
                              I am not sure why this is, please?
                              Thanks a lot,
                              Paul
                              Last edited by monsterjazzlick; November 11, 2017, 07:39 PM. Reason: Insert Images
